Basement Bathroom Addition - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-31-2015, 03:16 PM   #1
Rewards Points: 27
Hello. Working with a friend up in Ontario, Canada to add a basement bathroom .... He had roughed in the drains and I came to inspect the work. The tub and the sink both have ability to individually vent straight up but the toilet does not have a vent. The main stack is about 8-10' away but only distance wise --- if you follow the linear drain its much more than that. We want to vent the toilet seperately and our idea was to change out the 4" elbow to the toilet flange to a 4" Tee. We will come off the back of the tee with a 2" dedicated vent pipe until it ties in further up the stack.... Will this be sufficient? Issue 2: Can we externally vent this bathroom (pipe outside the house) or does It have to run on the interior? We can tie into the existing cast iron stack but running a separate exterior vent would be quick and easy and minimize damage to the house. Basement Bathroom Addition-image-139905470.jpg Broad view of bathroom rough in
Shows relation distance to furnace... The main stack is behind this furnace.
Elbow that was there. Tee we want to put on
RomanDesign is offline   Reply With Quote
Old 12-31-2015, 05:14 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 186
The code I work with does not allow that method of venting a toilet.
I also notice a san-tee on its side picking up what I assume is your tub. That is not allowed either- no san tees on their side when used for drainage. It needs to be a wye instead.
I also don't recommend running a vent up the exterior of the house.
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (12-31-2015), RomanDesign (12-31-2015)
Old 12-31-2015, 05:44 PM   #3
Rewards Points: 27
Originally Posted by TheEplumber
The code I work with does not allow that method of venting a toilet. I also notice a san-tee on its side picking up what I assume is your tub. That is not allowed either- no san tees on their side when used for drainage. It needs to be a wye instead. I also don't recommend running a vent up the exterior of the house.
How would you recommend venting the toilet. We would have come off the side of the pipe if we had more depth to work w because I know it has to be at a 45degree angle to the plane of the pipe and our floor height would not allow this
Old 12-31-2015, 07:39 PM   #4
Rewards Points: 582
I would suggest to call the local authorities in your area to get the details on your plumbing code and inspector...Iam with e ..you should not vent a commode like that...meaning a 4" tee on its back...and your 4x2 or 1 1/2 tee on its side again no no 4x11/2 wye would be code approved in the usa not sure about you area....
Basement Bathroom Venting Beepster Plumbing 5 11-24-2014 09:44 AM
Basement Bathroom, drop tile ceiling... Spyrule Remodeling 2 08-01-2014 10:21 PM
bathroom subfloor (Basement) BlueBSH Building & Construction 27 12-02-2011 10:10 AM
Bathroom addition in attic to basement drainage tmtoddsr Plumbing 3 05-16-2011 07:21 PM
Help with basement bathroom vent satchfan Plumbing 3 12-26-2010 09:35 PM
