Basement Bathroom - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-17-2015, 11:31 PM   #1
Rewards Points: 2
basement bathroom
Hello all
I am wanting to put a bathroom in my basement and have some ?'s. My main water line and waste line are in the center of the room and would like to move them maybe six feet. what are the steps I need to do. the main waste is cast iron not sure about the water line. The house is 55 years old and in Minnesota if that has a bearing on things.
tazpyro1 is offline   Reply With Quote
Old 08-17-2015, 11:48 PM   #2
Rewards Points: 5,348
You will need a permit and a plumber in most cases.
Floor gets broken up so new lines can be run under the floor.
Ron
B. Franklin 1759
Old 08-18-2015, 11:54 AM   #3
Rewards Points: 794
A pic of your space would help. If the sewer line runs through your space, that is good as not much floor will need to be broken up.
B
Beepster is offline   Reply With Quote
basement bathroom breiding200 Plumbing 4 03-22-2011 10:40 PM
basement bathroom breiding200 Plumbing 2 03-15-2011 03:05 PM
Help with basement bathroom vent satchfan Plumbing 3 12-26-2010 09:35 PM
Basement Bathroom - Sheetrock - Moisture Issues. mikeynpz Building & Construction 2 05-24-2009 10:08 AM
Basement Bathroom Insulatation/VB? mfleming Building & Construction 1 05-06-2009 04:27 PM
