Basement Basin, Pump And Sewage Piping Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-17-2015, 08:09 AM   #1
Rewards Points: 16
Basement Basin, Pump and Sewage Piping Question
Well first of all the 24" Lid is broken. Basin brand is Jackel (SPF 24x36) .
I am looking to replace the pump (It works but why not while i'm down there) and get a new lid. I'm going to have to caulk the new lid in place as all the bolts are rusted off.
Pump is a Zoeller M267 ~ $300
Some people recommended Tramco 400S and some recommends Weil.
These pumps sit above the basin, whereas the Zoeller sits inside.
My question is if my proposed design will work. I want to be able to slide the lid off easily to access the pump for maintenance/replacement.
I'm reading some sources say to install the check valves horizontally. My proposed design would not work if that is the best way. Called Jackel about the check valves and the gentleman said I can install them either way but I'd still rather install it horizontally.
JustBolts is offline   Reply With Quote
Old 09-17-2015, 08:12 AM   #2
Rewards Points: 16
Well This is my first post and I cannot post links
Old 09-17-2015, 08:12 AM   #3
Rewards Points: 16
Current Condition: http://imgur.com/1wgOKJC
Proposed Design: http://imgur.com/h7DetGA
Old 09-17-2015, 01:47 PM   #4
Rewards Points: 1,932
Looks like a grinder pit do the basement toilets go into it? If so it may smell a lot.
Old 09-17-2015, 08:42 PM   #5
Rewards Points: 16
In fact it does.
I tried vacuuming what is left on the bottom with a wet vac = bad idea
whole house stinks now but luckily I have not moved in yet.
More problems
http://imgur.com/a/CfMyk
Basin is done. How could they put this POS in there knowing it will turn to crap like this.
I think put a new basin inside this one and put dirt all around it.
But then how would I connect the 3" sewage to it? Ugh... maybe it's time to call a plumber.
Old 09-17-2015, 10:32 PM   #6
You need to purchase a grinder sump kit that includes the basin. It needs to have air tight seals even where the pipe enters into the basin. Otherwise that nice smell gets sucked up by your furnace and ends up all over. I would strongly suggest removing the old one entirely and replacing with a new one. This is not a standard sump pump for storm water basin.
https://www.libertypumps.com/Product...=106&s=10&c=19
Old 10-08-2015, 09:50 AM   #7
Rewards Points: 16
EDIT:
ALL DONE
http://imgur.com/a/NlUCu
THANK YOU
Sewage pump for 1st floor bathroom, not basement? fetzer85 Plumbing 14 02-24-2014 07:56 PM
Sewage ejector pump in basement johnd2 Plumbing 8 12-07-2013 10:48 PM
Sewage ejector pump question Jdbrooks Plumbing 5 04-23-2013 07:38 AM
holes in sewage pump basin? marketbridge Plumbing 2 09-05-2012 02:38 PM
Adding a basement bathroom with sewage ejector pump qoncept Plumbing 5 07-13-2010 09:48 AM
