Barroom Sink Drain Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-17-2015, 05:42 PM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 18,410
Barroom sink drain question
The sink drain is not long enough for the p-trap to line up with drain line in the wall.
2 Choices
1. Extend the drain
2. Route the p-trap so it drops down to the drain pipe
I prefer the second solution because it give me more space under the sink.
What is the preferred solution?
Old 01-17-2015, 06:25 PM   #2
Retired Moderator
Rewards Points: 7,174
Best solution ? Either raise the drain for more cabinet space or use an extension to lower the trap
Do not create an S-trap to raise the drain--
Old 01-17-2015, 07:16 PM   #3
Rewards Points: 582
I perfer to see what you have...
Old 01-17-2015, 09:57 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 248
You can offset the tailpiece before the trap, but the outlet of the trap can not offset vertically.
So, either a tailpiece extension or raise the tee
Another possible option is an offset tailpiece that is used for wheelchair access, but not practible with a pop up drain.
Old 01-18-2015, 12:01 AM   #5
JOATMON
ddawg16's Avatar
I just noticed the pic I tried to post from my phone didn't post.
Old 01-18-2015, 06:08 AM   #6
JOATMON
ddawg16's Avatar
Ok....here is the pic
(sorry for the delay...it was one of those nights)
Old 01-18-2015, 06:09 AM   #7
JOATMON
ddawg16's Avatar
But I have to wonder.....as soon as the line enters the wall, it goes down. In terms of physics....what is the difference?
Old 01-18-2015, 07:04 AM   #8
Retired Moderator
The vent inside the wall allows the water to flow in the drain pipe----
An S-trap---uses the sink as a vent---and can possibly suck out the water from the P-trap
Common enough problem on a high volume vessel like a bath tub or kitchen sink--not to likely in a small bar sink.
Old 01-18-2015, 07:09 AM   #9
Rewards Points: 582
simple ..just get a tail peice extension....your done...
The Following User Says Thank You to ben's plumbing For This Useful Post:
oh'mike (01-18-2015)
Old 01-18-2015, 07:53 AM   #10
Retired Moderator
To easily understand the theory---get a length of clear plastic tubing--fill with water and stopper the end with your finger.
bend a P-trap shape and remove your finger---water will remain in the tube at the trap.
Next fill it and repeat with the S-trap shape---it will empty completely if the output end is lower than the bottom of the P-trap.
I only added this because I know you like the
"WHY" as well as the "HOW"
TheEplumber (01-18-2015)
Old 01-18-2015, 08:48 AM   #11
Plumber
Rewards Points: 248
2 Choices
1. Extend the drain
In order to get more room, you will need to configure the tailpiece like the image- only using ABS.
Use a trap adpt to connect to the sinks tailpiece, Then use a solvent weld 90 back to the wall where you can then 90 down to your trap.
Old 01-18-2015, 10:19 AM   #12
Master Plumber
Javiles's Avatar
Rewards Points: 1,012
a 22 0r 45 a short piece of pipe and tubular extension you're done.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 01-18-2015, 10:50 AM   #13
Rewards Points: 582
its not worth the time or amount of room you will gain....to do all the messing around IMO....extend the tail peice hook up the trap ..relax and have a beer football is on
Old 01-18-2015, 11:03 PM   #14
JOATMON
ddawg16's Avatar
Thanks for the input guys.
This is what I did today.....
And....I have determined that I am in fact OCD.
It's killing me the drain extension is white and not black.
And this is the sink....prior to granite....
The Following User Says Thank You to ddawg16 For This Useful Post:
oh'mike (01-19-2015)
Old 01-19-2015, 06:50 AM   #15
Rewards Points: 582
perfecto painless as well but you get a F for mixing pvc and abs
New Sink Drain Seal caveeagle Plumbing 6 02-10-2014 08:22 PM
Farmhouse sink install question Master Brian Remodeling 1 10-22-2013 02:43 AM
PVC sink drain pipe... Ed911 Plumbing 4 12-01-2011 10:09 AM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 09:11 PM
