Ball Valve To Reduce Flow In Sump Pump Discharge Line? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree13Likes
Old 02-23-2018, 10:34 AM   #31
tom_poconos's Avatar
Rewards Points: 508
Re: Ball valve to reduce flow in sump pump discharge line?
Originally Posted by DR P View Post
do you have a relief hole inside sump piping?
Yep, there's a 1/8" hole in the pipe before the check valve, angled 45 degrees down toward the sump.
definately limits your water removal capabilities entering sump
Willing to risk this - the runoff build up is fairly slow. Since it can currently empty the sump in a matter of seconds, I'm ok with it running for a few minutes, ten times per year (that's my conservative estimate on the flooding frequency - so far it only occurs in the relatively infrequent event of heavy rain after heavy snow).
if end outside freezes shut
I'm really up **** creek without a paddle if the end freezes up before a flooding event. Hopefully though those two events are mutually exclusive - it has only flooded during non-freezing temps.
On the one ton temple bell
a moon-moth, folded into sleep
tom_poconos is offline   Reply With Quote
Old 02-23-2018, 10:48 AM   #32
Peace be with you
DR P's Avatar
Rewards Points: 1,860
https://www.homedepot.com/p/Re-Useab...WD21/204116885
they make these cheap enough leak monitors; just saying
Peace
Nealtw likes this.
My comments towards your questions & concerns are based on my work history, knowledge, & past experiences; they are my opinions given freely in hopes they truly help/bless U. That said, if U don't consult with & or hire a licensed professional locally, then please don't blame me when You DIY... Bottom line - Safety 1st & Always; got that???
DR P is offline   Reply With Quote
Old 02-23-2018, 05:15 PM   #33
Rewards Points: 1,932
Originally Posted by tom_poconos View Post
Sump pump is pumping runoff when the basement leaks after heavy rain and snow melt. It's not going to septic, it's going out a new line I plumbed. Along this line I decided to create some T's and connect some other appliances that need gravity drainage. I also have an ejector pump for a laundry tub and washer which goes to septic, but it's not well positioned to have many appliances drain into it, not to mention it is too high for some of the gravity fed drains. I'm only using this new discharge line for runoff or clean water (condensate).
Can you run your clear water condensate to the sump itself? Then just plug your tie ins.
Old 02-24-2018, 06:31 PM   #34
Rewards Points: 508
Here it is - the Millennium Falcon of flow control.
macnetism likes this.
Old 02-25-2018, 10:48 PM   #35
retired framer
Rewards Points: 15,280
With the smaller pipe you have already restricted flow.
The Following User Says Thank You to Nealtw For This Useful Post:
tom_poconos (02-28-2018)
Old 02-28-2018, 10:21 AM   #36
Rewards Points: 508
Yep, the valve is now for "extreme throttling mode". This setup with a cleanout was $1 cheaper than a 1 1/2" ball valve
Sewer gas, septic and sump pump, only when it rains.-help heydiddle27 Plumbing 4 04-12-2016 02:32 PM
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Sump pump discharge reduced for velocity and short cycling? rebar Plumbing 2 05-05-2013 07:11 PM
Sump Pump drainage and other flow problems loomis1228 Plumbing 5 03-24-2011 04:18 PM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
