Bad Smell - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree5Likes
Old 02-17-2018, 09:53 AM   #16
Rewards Points: 6,322
Re: Bad Smell
OK, another bell rang.
Clean the hair from the pop up assembly. That's the most common problem with lavatorys in every household. As mentioned, sometimes the Clorox will do it if it can be retained in the hair area long enough.
Old 02-17-2018, 10:06 AM   #17
JUSTA MEMBER
Rewards Points: 3,780
Re: Bad Smell
Is there a person in the home with long hair?
Some times long hairs get trapped in the piping downstream from where you can easily see, and then accumulates more hair, dirt, soap film, anything else that is washed away.
Then rots.
Stinks like dead animal.
ED
de-nagorg is online now   Reply With Quote
Old 02-17-2018, 10:27 AM   #18
Rewards Points: 20
Re: Bad Smell
The popup, drain, and trap are totally clean. That was my first thought months ago. The problem seems to be down stream but more than likely in the vent stack. The shower and toilet that use the same drain work fine, no issues at all or smell.
In Virginia is offline   Reply With Quote
Old 02-17-2018, 10:50 AM   #19
Rewards Points: 2,782
Re: Bad Smell
Just to comment, you mentioned gurgling. If there is a block beyond the trap that is slowing the drain then when you first run some water it might force some of the air beyond the trap to bubble back to your side. The blockage is not total as you tested it and it does drain, but once the water is running it could complete the block and fill more of that space resulting in the air needing to go somewhere.
Under the sink, is your trap removable where it heads into the wall? If you can snake from there you might have more luck. I have a snake that allows me to spin the cable as I insert it and I have attached objects to that end so they spin a larger diameter.
The solution will look obvious once you find it. For some comfort, plumbers in my area get $200 an hour to do what you are doing.
Bud
Bud9051 is online now   Reply With Quote
Old 02-17-2018, 11:21 AM   #20
Re: Bad Smell
Hey Bud, I'm bout tired of this bell ringing.
To rule out the vent as the problem, if you have a leaf blower available, blow air into the vent stack while someone watches the water level in the toilet. If the wife screams the vent is open and you may have a mess to clean from the floor.
Old 02-17-2018, 11:21 AM   #21
Rewards Points: 20
Re: Bad Smell
The other thing that no one had addressed is why when I snaked the vent from the roof and the end was wet, why is that, shouldn't a vent be dry. There are no traps in the main line below the vent to hold water.
Old 02-17-2018, 12:18 PM   #22
Re: Bad Smell
Basically you are correct but there can be unintended low spots that can hold some water. Since the toilet is flushing fine if it is a vent issue I would think it was just the vent connection from the sink. There may also be a vent connection from the shower or tub, being that the MBR has its own vent stack.
I think you said you removed the trap at the sink, did or can you try the snake from there?
Bud
Old 02-17-2018, 01:55 PM   #23
Naildriver
chandler48's Avatar
Rewards Points: 3,478
Re: Bad Smell
Don't forget, too, running that snake down the pipe could act like an errant NG tube down your nose, and go into your lungs, or into a trap to the side of the vent.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 02-25-2018, 06:16 AM   #24
Rewards Points: 20
Re: Bad Smell
Update - I poured more drain cleaner down the drain and some into the sink overflow. Both of these worked well but I thought, what the heck, it's worth a try and guess what, no more smell in the morning when we run the water. I just hope it stays that way.
Thanks for all the replies. Keeping my fingers crossed.
de-nagorg likes this.
Old 02-25-2018, 06:23 AM   #25
JUSTA MEMBER
Re: Bad Smell
A regularly scheduled interval of using the cleaner, will keep the mess at bay.
Even a dose of pine-sol would keep it smelling better.
ED
Persistent Burning Smell for Over 18 Months Lynn333 HVAC 21 01-24-2016 11:35 AM
Smell coming from all floor registers. John_W HVAC 10 08-07-2015 06:42 PM
Bad smell in crawl space. John_W General DIY Discussions 34 06-03-2014 12:57 PM
Smell when boiler runs? dave12345 HVAC 13 11-11-2013 08:08 AM
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 01:51 PM
