Backing Up Again - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By Yodaman
Old 01-01-2017, 02:55 PM   #1
Rewards Points: 1,218
Backing up again
So my tenants tub is backing up again which is on the ground floor about 15' from this trap. It seems like ever since we had our cesspool pumped about 3 months ago we've have a poop smelling odor and backing up periodically. I'm gonna rent a motorized snake to see if there's a clog. Input our hand snake down there last week and came up with some toilet paper etc and their tub drained and the water at the trap/pipe went down...but now it's happening again.
Mstrlucky74 is offline   Reply With Quote
Old 01-01-2017, 03:37 PM   #2
Property Mgt/Maint
Rewards Points: 8,202
Re: Backing up again
I see leaves. Trees in close proximity?
BlackTiger likes this.
Yodaman is offline   Reply With Quote
Old 01-01-2017, 04:04 PM   #3
Rewards Points: 1,054
Cast iron or PVC main drain pipe?
clarenceboddick is offline   Reply With Quote
Old 01-01-2017, 05:28 PM   #4
There's an upside down U that connects to the pipe so it's hard for things to get into there.
Old 01-01-2017, 05:34 PM   #5
I think he's asking about the trees because of roots.
The Following User Says Thank You to clarenceboddick For This Useful Post:
BlackTiger (01-01-2017)
Old 01-01-2017, 05:40 PM   #6
Property Mgt/Maint
Yes, a sewer line is like the fountain of youth to a tree root. Any little gap or crack and they find their way in. Hope that's not your problem.
Old 01-01-2017, 09:05 PM   #7
No trees close by. I'm gonna try to snake main line then if no relief call is plumber. Leaves were from my blower.
Old 01-01-2017, 09:34 PM   #8
JUSTA MEMBER
Rewards Points: 3,992
I hate to inform you that you have an unworkable idea trying to snake that vent pipe.
There should be a double cleanout on that, so you can snake both ways out to the tank, and back into the house.
Trying to snake that vent is going to be hard to do, if not impossible.
ED
de-nagorg is offline   Reply With Quote
Old 01-01-2017, 10:10 PM   #9
ED
No problem. So what do you suggest I do or tell the plumber?
Wierd bathtub caulk backing material eharri3 General DIY Discussions 3 05-02-2014 09:03 PM
Wallpaper removal & brown paper backing _alphaBeta_ Drywall & Plaster 4 09-10-2012 08:26 PM
Spackle over wallpaper backing angelabatwood Painting 6 06-10-2012 05:41 PM
Asbestos Vinyl Sheet Flooring Backing Codyy Safety 3 01-04-2012 11:09 PM
Painting over backing after removing vinyl wallpaper zachinqueens Painting 5 10-02-2011 05:00 PM
