Aqua System ARB18 Expansion Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-30-2017, 11:54 AM   #1
Rewards Points: 2
Aqua system ARB18 Expansion Tank
I am not a plumber and have not used these tanks before.
However, a qualified plumber did fit this tank using a couple of screws through a dry wall.
It has now fallen off, pulling away some of the plaster with it!!!
I shouldn't be surprised as they fell off in both my neighbours' houses too!
I have refitted it to the wall properly fixing it to wood so it will never fall off again.
My question is; does it matter if it is mounted upright or transversely?
The plumber fitted it transversely (on a hook mount) however it seems to make more sense fitted upright.
I can not find any information about this via google, so apologies for troubling you with this.
Pete
petethorp is offline   Reply With Quote
oil furnace expansion tank ? gwilkrrs HVAC 5 01-14-2014 05:35 PM
Pressure difference between supply and expansion tank JasperST Plumbing 5 09-29-2013 10:44 AM
Help with insulating expansion tank. Idlewild294 Plumbing 8 03-29-2013 08:29 PM
Septic tank missing T and badly angled main line? denemante Plumbing 3 11-22-2011 09:29 AM
Pressure relief leaking and expansion tank full themow HVAC 1 11-25-2009 04:49 PM
