Anything Wrong W/ Toilet Drain? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-04-2016, 12:25 AM   #1
Rewards Points: 1,178
Anything wrong w/ toilet drain?
Does anyone see anything wrong w/ this? The picture was taken from directly below and shows the drain for a toilet (drain #1) and the tail end of another drain (drain #2). Drain #1 and drain #2 join through the horizontal T-Y. The toilet is 7 pipe feet from the shower vent, which comes off of drain #2. Thanks. john
Anything wrong w/ toilet drain?-toilet-2-vent-line.jpg
Old 11-04-2016, 03:59 PM   #2
Rewards Points: 1,862
Re: Anything wrong w/ toilet drain?
Your 2 inch vent must be a draining a vented fixture in that bathroom. Otherwise under IPC code it would be an illegal dry flat vent.
Old 11-04-2016, 09:34 PM   #3
I'm not sure I follow what a "draining vented fixture" is. The 2" vent is rolled over at 45 degrees. That is how a plumber did it in the below-slab piping for the lower toilet, if I recall correctly. How should the 2" vent be oriented here? Thanks much. john
The Following User Says Thank You to jklingel For This Useful Post:
gary.bruzzese (11-05-2016)
Old 11-05-2016, 01:30 PM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 1,012
What Ghost means is that 2 vent inch line must have water draining through it via a sink, tub, etc., you need the secondary water to keep that vent and toilet line clean.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 11-05-2016, 01:47 PM   #5
OK. I sort of figured that out last night, but thanks for confirming. Thus, I guess I need to lay that vent over flat then? Thanks. john
Old 11-05-2016, 06:18 PM   #6
The vent needs to go to your bathroom sink and pick it up with a vent off the top.
Old 11-05-2016, 10:13 PM   #7
OK. Got it. Thank you. Will this WORK, though, even if it fails inspection? Changing all this right now will really cram us up; several months from now would be a lot more convenient. John
Old 11-06-2016, 08:33 AM   #8
Just change it when you can your weather is going to be a cold winter this year.
Old 11-06-2016, 12:01 PM   #9
Again, many thanks. We will fix it eventually. So far, winter is very mild, but you never know. cheers. john
Toilet Install Went Wrong, Poor Plumber Choice pbrigante Plumbing 12 08-10-2014 09:35 PM
Trane XE80 - Drip pan filling up. Drain setup wrong? Please help :) Mognar HVAC 5 06-09-2014 10:52 PM
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
Toilet Flange Inside or Outside Drain Pipe? sledged Plumbing 23 01-18-2012 12:18 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
