Anyone Able To Decider Wayne Pump Date Codes? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-25-2016, 08:00 PM   #1
Rewards Points: 114
Anyone able to decider Wayne pump date codes?
Just replaced this pump.. wondering how old she might be. I understand the date code is the MOD. Not opposed to calling up Wayne just curious in the meantime.
Anyone able to decider Wayne pump date codes?-1461632339121-2035000481.jpg   Anyone able to decider Wayne pump date codes?-20160425_195433.jpg
Phases is offline   Reply With Quote
Old 04-25-2016, 10:07 PM   #2
Rewards Points: 3,234
Re: Anyone able to decider Wayne pump date codes?
Just a guess:Jan 03,1976. About 40 years if i'm right. Long time.
Could be coded in the model number like you say. Idk for sure. Some manufactures code that info into the serial number. Your serial number is ymj010376.
jmon is online now   Reply With Quote
Old 04-26-2016, 07:53 AM   #3
Rewards Points: 114
I called the company, they asked for the model, then the four digit "Serial Number" sticker that isn't on the GE sticker. Which is 4978 as you can see in the first sticker.
Then he had me guess the age lol. I said 15-17 years (our house was built in 97) so I just took a stab at it.
He said "it was Manufactured in October of 1997" heh.
So. Not 40, but over 18 which impresses me enough considering the conditions it was working in.
The sediment that I assume killed it (the footer was basically buried in it) came pouring out of holes and slots in it when I was moving it around yesterday to find additional markings.
I wish everything lasted this long!
The Following User Says Thank You to Phases For This Useful Post:
jmon (04-26-2016)
Old 04-26-2016, 08:33 AM   #4
Me too.
Circulator pump: guilty or not guilty? alight9010 HVAC 15 12-28-2015 08:43 PM
Well pump trips breaker at start, but then starts when breaker reset J. David Electrical 34 02-25-2012 11:23 AM
Intermittent submersible pump fault esquilax Electrical 5 09-30-2011 03:56 AM
Sump pump large draw of power BlueBSH Electrical 1 03-16-2011 10:51 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
