Any Issue Re-doping Gas Lines? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-03-2016, 03:15 PM   #1
Rewards Points: 290
Any issue re-doping gas lines?
I noticed the gas line going to my hot water heater has a slight gas smell around it. I tried leak detector but can't get any bubbles, but putting a nose right up to the fittings I found one that's markedly more noticeable.
Any harm in removing the pipes piece by piece to the fitting and redoping it back from that point?
Is there any trick to clean it the old dope off?
gizzygone is offline   Reply With Quote
Old 02-03-2016, 03:32 PM   #2
Retired Moderator
Rewards Points: 7,174
Go ahead and take them apart--use dope and tape when you put them back together.
If that fails---replace the fitting that is leaking---
Old 02-03-2016, 03:33 PM   #3
Rewards Points: 8,349
There is one brand of pipe dope that has an odor similar to the chemical used in NG. If it doesn't blow bubbles it is a very tiny leak indeed. I suggest spraying all the fittings in the general area. I have also seen flex hoses have very tiny leaks in the pipe body. That one entertained for for quite a while before I found it.
If proceeding, no problem; iron pipe can be redoped and reused.
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is offline   Reply With Quote
Old 02-03-2016, 03:36 PM   #4
Rewards Points: 290
Dope and tape?
Old 02-03-2016, 03:38 PM   #5
I only use dope on iron pipe. BTW, a paper towel or rag will remove all the old stuff that really needs to come off.
Colbyt
Old 02-03-2016, 04:26 PM   #6
WhatRnsdownhill's Avatar
Rewards Points: 2,220
if spray doesnt show any bubbles, try dish washing soap and some water in a cup and with a brush lather up each pipe joint well and then look for bubbles, sometimes spray doesnt coat completely..
WhatRnsdownhill is offline   Reply With Quote
Old 02-03-2016, 04:31 PM   #7
Rewards Points: 582
it is ok to undo piping and reinstall it....shut of gas ...remove old pipe clean threads apply new pipe dope tighten back up ..turn on gas test for leaks
Old 02-03-2016, 04:33 PM   #8
Retired Moderator
Originally Posted by gizzygone View Post
Dope and tape?
I use both---perhaps over kill--but I got into the habit when runnig 4" threaded that was heated and pushing melted chocolate under high pressure---(don't ask--I've done some odd work in my life)
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
ben's plumbing (02-03-2016), Yodaman (02-04-2016)
Old 02-03-2016, 04:37 PM   #9
Rewards Points: 582
its ok you use both tape and pipe dope....I don't because thats how i was taught and never had any problems...
The Following User Says Thank You to ben's plumbing For This Useful Post:
oh'mike (02-03-2016)
Old 02-03-2016, 04:51 PM   #10
Retired Moderator
I never had a need before those 4" chocolate pipes---the small extra effort was worth it--4" is not fast or easy--and having to rework them due to seepage made the dope and tape worth while.
Old 02-03-2016, 06:36 PM   #11
Rewards Points: 1,914
Not sure if anyone else mentioned it but no tape or dope is used on flare fittings, dope alone or dope plus GAS rated tape can be used on others. Ron
ront02769 is offline   Reply With Quote
Old 02-03-2016, 07:23 PM   #12
says who? flare fittings for gas,use dope to help make the seal and help lube the threads...
Old 02-03-2016, 10:00 PM   #13
Most dopes will eventually dry up then you'll have a leak. I use bearing grease (used to use hvac oil) on my flares.
Here's a leaker from yesterday.
hvac benny is offline   Reply With Quote
Old 02-03-2016, 10:51 PM   #14
the pipe dope I use on any unions or flares is oil based and never dries up, yes many dry to a hard cracking piece of crapola..I use Hercules grip on any threads that never have to come apart, it stays slightly flexible forever.
Old 02-04-2016, 03:27 AM   #15
Rewards Points: 5,664
You get a big fat red check mark on that test question and stay out of the hydraulic department.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
SHR Plumber (02-04-2016)
Concrete shower floor and drain issue whoowl Kitchen & Bath Remodeling 0 07-24-2015 04:10 AM
Speaker Wire/Network lines gec5741 Home Theater 2 04-24-2013 10:19 PM
Transplant tree near underground utility lines? BrandonC_1972 Landscaping & Lawn Care 11 08-26-2012 05:43 PM
wall out of plumb how do you tile it and have decent visuals. grout lines off by 1/4 papason Tiling, ceramics, marble 2 08-11-2012 02:46 PM
Drain lines for Mini Splits dbargaehr HVAC 2 05-24-2011 01:02 PM
