Another Rough-In - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-12-2017, 07:34 PM   #1
Rewards Points: 4
Another Rough-In
Greeting all...
First post and with another rough-in challenge. I have seen a lot on here already and figured I would throw mine out there.
As in the others posts, I will be renovating my basement and need to plan out this bathroom. What are the rough-ins for? Now I have no vent pipes or water supply overhead in the joists. I was looking at the local code and they mentioned something about Air Admittance Valves instead of using vent pipes. This is the first I've ever heard of this and is this something that I can use instead of trying to tap into a pipe in a bathroom upstairs?
Thanks, all and look forward to participating on these forums throughout this process.
WyattB is offline   Reply With Quote
Old 07-12-2017, 08:05 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,886
Re: Another Rough-In
You'll have to check your local jurisdiction if they permit AAV's. (It's basically a one way air valve that allows air to enter your vent pipe but gases not to exit....and consequently does not require external venting)..... but many jurisdictions have different opinions on their use.
MTN REMODEL LLC is offline   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
WyattB (07-12-2017)
Old 07-13-2017, 12:25 AM   #3
retired framer
Rewards Points: 15,718
If possible go for a real vent.
Rough in valve function question spacepunch Plumbing 11 01-04-2017 09:50 PM
Very noob question about rough opening on door sonnaps Building & Construction 44 09-08-2015 07:28 PM
Toilet and Shower Rough In Dimensions VikingDinKC Plumbing 16 05-13-2012 01:50 PM
Basement Toilet Rough In - Help atm Plumbing 3 06-06-2009 11:04 AM
Replace a 10" rough in toilet with a 12" rough in Opie46 Plumbing 3 05-16-2009 11:27 AM
