American Standard Ghost Flushing - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-25-2016, 07:19 AM   #1
Wildbill7145's Avatar
Rewards Points: 180
American Standard ghost flushing
So, doing a little web surfing leads me to believe this is a widespread problem across the board in all of their models of toilets. We bought ours a few years ago and all of a sudden recently it's started leaking into the bowl causing the tank to refill when the level gets low.
I changed the flapper gasket thing yesterday thinking this would resolve the issue, however it's still doing it.
Has anyone ever figured out a solution to this problem. Going to their FB page and reading the comments left by customers makes me think there's a lot of people out there with exactly the same problem, but American Standard isn't doing anything about it.
Edit: Forgot to mention we have the Champion 4.
Wildbill7145 is offline   Reply With Quote
Old 08-25-2016, 09:43 AM   #2
Rewards Points: 5,520
Re: American Standard ghost flushing
I've corrected the leaking flush valve problem two different ways on 2 different toilets. ( not on American Standard ).
1) Installed complete new flush valve
2) Installed " Korky " flush valve re-build kit
Re-build kit is by far the faster of the two methods with by far less frustration. End result on both was successful.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Wildbill7145 (08-25-2016)
Old 08-26-2016, 08:10 PM   #3
Rewards Points: 1,854
Flusher fixer is also a good alternative.
Old 08-26-2016, 09:43 PM   #4
Rewards Points: 1,832
Needs a new Flapper or flush valve.
Jump-start is offline   Reply With Quote
american standard basin, tub, shower faucets FISH96 Plumbing 1 01-08-2013 04:02 PM
American Standard Heat Pump Issue CharlesT HVAC 13 09-06-2012 09:10 AM
American Standard Toilets rick31797 Plumbing 1 06-05-2012 07:16 AM
American Standard Mr Smiley HVAC 4 02-24-2012 02:38 PM
American standard heat pump question. SS laser HVAC 5 01-04-2012 09:35 PM
