Am I Silly For Wanting To Delete My UV Filter?? Low Water Pressure @ Taps - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
Old 11-19-2016, 07:07 PM   #16
Water Treatment
Akpsdvan's Avatar
Rewards Points: 1,184
Re: Am I silly for wanting to delete my UV filter?? Low water pressure @ taps
You did a bypass, good for you, but you bypassed not just the uv light but also the pre filter.
So now the Question which was the block? The Filter or the UV??
UV light is rather straight forward in that water in and water out the light is in the middle and a sleeve around the light.
When was the last time that the pre filter was changed and what micron is that pre filter?
Akpsdvan is offline   Reply With Quote
Old 11-19-2016, 07:25 PM   #17
Food Truck & Old House
Rewards Points: 332
Im aware i bypassed the sediment filter and the uv, i basically reverted back to the routing that was used before this fancy system was installed, and it worked.
The filter is 5micron, as recommended by the manufacturer, changed about a month ago, as I stated
I removed the sediment filter this evening, closed my bypass valve, and flow dropped again.
I have all the fittings/pex needed to redo the system and delete alot of unnecessary fittings and 90s
KevinEF7 is offline   Reply With Quote
Old 11-20-2016, 01:45 AM   #18
Rewards Points: 332
A little more streamline and less janky looking, shutoff valve is off of the bladder tank T at the bottom, kind of hidden in the picture. Uv system completely cutout
Flow increased again aswell, marginally, could be in my head, but alot better than last week.
Found no blockages in any of the piping I removed. Safe to say the sediment filter was the problem
Am I silly for wanting to delete my UV filter?? Low water pressure @ taps-20161120_011111_1479626587870.jpg
Old 11-20-2016, 06:51 AM   #19
Super Moderator
joed's Avatar
Rewards Points: 31,972
Have you had the water tested again?
Old 11-20-2016, 06:59 AM   #20
An old Tradesmen
Rewards Points: 9,474
Its probably the 5 micron filter.
Old 11-20-2016, 09:25 AM   #21
Rewards Points: 316
I use a system quite similar to yours (although different manufacturers) and have no pressure problems at all even with a 1 micron sediment filter. I was wondering if possibly the filter cannister was installed backwards. There is usually an inlet and outlet labeled.
beenthere likes this.
daveb1 is online now   Reply With Quote
Old 11-20-2016, 12:00 PM   #22
Rewards Points: 332
I will be bringing a water sample in for testing on Monday yes just for peace of mind. Wife noticed the flow bump in the shower and she didnt even know I was down there doin it in the middle of the night. Im in the good book this week!
Appreciate all of the helpful comments
Old 11-20-2016, 05:56 PM   #23
Usually Confused
lenaitch's Avatar
Rewards Points: 2,072
Bask in good book! I just noticed your location. Follow the collection and labeling instructions closely or they might reject the sample. Also, watch your timing - the sample has to be fresh, and it's different if you are able to take to a local lab vs. just a local health unit office since they have to ship it to a lab.
lenaitch is offline   Reply With Quote
Low water pressure + storage tank pyotrbee Plumbing 1 08-28-2012 07:02 PM
Well Pump Pressure Problems LTY83 Plumbing 15 06-30-2012 02:58 PM
no hot water pressure in sink, but plenty in tub Turtle learner Plumbing 5 10-20-2010 07:45 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 10:29 PM
