Air Admittance Valve In Island - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-22-2017, 03:06 PM   #1
Air admittance valve in island
Hi all,
I'm trying to get unconfused about using an AAV for a kitchen sink in an island. Local code seems to quote the IPC. But that section is confusing to me.
If I use an AAV at the sink, what is the requirement for the vertical placement of the valve?
Does there still have to be an actual vent stack pipe associated with this fixture someplace?
Does anyone have a good graphic showing an example of what meets the code?
Thanks very much.
kw
Soundside is offline   Reply With Quote
Old 05-22-2017, 06:06 PM   #2
Rewards Points: 898
Re: Air admittance valve in island
Originally Posted by Soundside View Post
Hi all,
Thanks very much.
kw
http://s3.amazonaws.com/finehomebuil...74056-main.jpg
BIG Johnson is offline   Reply With Quote
Old 05-22-2017, 06:51 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 248
Hi all,
Thanks very much.
kw
I can't tell you IPC code, but you are pretty safe if you use a AAV that is listed with IPC, ICC or UPC.
There are 5 variants of the UPC within 50 miles of my house so I usually call my inspector with any questions such as yours.
Follow the manufacturers directions too and leave those instructions for the inspector to review.
Old 05-23-2017, 06:27 PM   #4
Rewards Points: 1,930
Call your local plumbing inspector. Some areas have decided to use the AAV manufactures engineering documentation and enforce a vent on the local branch to relieve positive air pressure. Manufacture documentation can overrule the code.
Old 05-23-2017, 08:16 PM   #5
Rewards Points: 898
Go to 3:45
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Delta shower valve replacement on exterior wall muellertr Plumbing 6 01-02-2013 07:07 AM
Main Water Shutoff Valve problem obadran Plumbing 16 12-10-2012 11:45 AM
AIR ADMITTANCE VALVE in Ky. Yourbroker76 Plumbing 1 05-29-2012 11:32 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
