Advice On Removing CI Closet Bend - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-05-2015, 07:43 PM   #1
Power Gen/RS Engineer
Rewards Points: 566
Advice on Removing CI Closet Bend
Currently remodeling my 100 year old Bohemian. We are reconfiguring the 1st floor bathroom and adding a separate toilet room which means that the old closet bend needs to be removed from its currently location. Attached is a picture that shows the existing piping which appears to be cast iron.
How would a plumber typically approach this removal? More than likely I will not be performing the work myself but I'd like to simply understand what options are available.
Thanks in advance,
Jimmy
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 12-06-2015, 07:02 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,240
Ayuh,... Cast iron pipe is easy to smash with a BFHammer to remove it,....
Bust it out, then replace/ reroute/ cap it off with pvc,....
Join the pvc to any iron still used with fencos,...
Removing concrete stone from fireplace - Need How To Advice cheese1478 Remodeling 3 08-29-2012 09:02 AM
Framing a new header for closet opening jmai14 Carpentry 6 07-09-2011 02:20 PM
Laundry closet decision LClark Remodeling 2 06-26-2011 06:19 AM
Basement closet bend not plumb lbbaileyjr Plumbing 1 04-17-2011 12:25 PM
advice in removing plastic drain valve from water heater darsunt Plumbing 1 06-15-2009 04:30 PM
