Advice On Adding A Residential Outdoor Spigot - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-15-2017, 04:04 PM   #1
Rewards Points: 904
Advice on Adding a Residential Outdoor Spigot
I am wanting to add an outdoor spigot on my home. I have attached pics of the water line that I am wanting to come off of. The pipe that I am wanting to come off of is circled in the pictures. The spigot would go straight to the outside of my house. The white pipe to the left in one of the pictures is my pipes for my sprinkler system.
Advice on installing the spigot, please. The spigot would be exiting the house through the concrete foundation.
I am pretty comfortable doing this job but just wanted to see if I could get any advice on performing the task prior to starting it. Thanks!
Advice on Adding a Residential Outdoor Spigot-100_li.jpg   Advice on Adding a Residential Outdoor Spigot-101_li.jpg   Advice on Adding a Residential Outdoor Spigot-102_li.jpg
kennykenny is offline   Reply With Quote
Old 06-15-2017, 05:47 PM   #2
Rewards Points: 1,928
Re: Advice on Adding a Residential Outdoor Spigot
Who ran the pipe for the sprinkler? PVC is not approved for water distribution piping.
Old 06-15-2017, 09:30 PM   #3
Rewards Points: 904
Was like that when I moved into the house. 2nd owner. What is it supposed to be?
Old 06-15-2017, 11:34 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 248
CPVC, PEX, or copper
For your bib, I recommend exiting in the rim joist. This seems to give you a wood surface to anchor to rather than concrete.
You can cut into the pex, install a tee and pipe to the bib. There are multiple joining systems for pex- including "sharkbite" fittings. Just pick the one you like
Need advice on riwiring and adding shop lights to my small garage speedster1 Electrical 3 12-04-2012 07:09 PM
Repainting Room With Peeling Paint: Advice Needed Magnetic Painting 8 10-15-2012 05:19 PM
need advice: to insulate or not to insulate? kelaguen Roofing/Siding 13 11-04-2010 03:41 AM
adding 2nd floor circuit by running wires outside in PVC - advice? reags Electrical 16 08-06-2010 10:32 AM
Advice for adding sump pit/pump pkovo Plumbing 9 09-20-2009 07:26 AM
