Adding Water Line For Fridge - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By BayouRunner
Old 09-21-2016, 08:36 PM   #1
Rewards Points: 64
Adding water line for fridge
I'm getting a new fridge which has water and an ice maker and I need to run a new water line. Here's a picture of the hot and cold lines under the sink. The black line you see is going up to the sink.
What's the best way to do this? I've researched a bit online, but I'm still not clear as to how to attach the new valve. Or which valve to get. I have purchased a 25' braided stainless steel line, 1/4 inch.
I have never worked with a torch or copper before.
Thank you! You guys always come through.
lisaabrams is offline   Reply With Quote
Old 09-21-2016, 10:35 PM   #2
Rewards Points: 18,794
Re: Adding water line for fridge
Got a mess under there and a lot of parts that are not needed.
Those supply lines could have been connected right to the stops without that copper pipe if they were longer.
The way that's plumbed your stuck with having to unsolder that left hand stop in order to install a new double headed stop.
Old 09-22-2016, 06:08 AM   #3
Rewards Points: 564
They sell brass tees that are 3/8 on two sides, 1/4 on the other. Pretty easy fix as you install it after the valve
SHR Plumber likes this.
BayouRunner is offline   Reply With Quote
Old 09-22-2016, 06:17 AM   #4
Rewards Points: 564
The Following User Says Thank You to BayouRunner For This Useful Post:
rjniles (09-22-2016)
Old 09-25-2016, 07:50 PM   #5
Rewards Points: 64
Thanks! Do you know if it comes in 3/8 x 1/4 x 1/4?
The line to the fridge and sink are both 1/4. I went to a local hardware store today and they didn't have this item. Off to the plumbing supply store tomorrow with hopefully better luck!
Old 09-25-2016, 09:13 PM   #6
Rewards Points: 564
Your frig is normally 1/4. Your faucet looks like 3/8. I've not seen 1/4 supply line to a faucet. So you will need 3/8 on two sides and 1/4 on one
Redoing plumbing - water service line (main) joemc3 Plumbing 19 04-10-2014 03:20 PM
How to seal water line on outside to prevent leak into basement goshenplumber General DIY Discussions 14 10-27-2013 01:56 AM
vacuum breaker question detroittigerfan Plumbing 17 10-12-2013 01:37 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 09:26 PM
