Adding Rain Shower Head - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-23-2016, 10:01 PM   #1
Rewards Points: 83
Adding rain shower head
Hey all, I am redoing my main shower. I have 1/2" supply lines to the control valve. I am wanting to add a rain shower head on a 2nd line and keep the existing shower head also. Will the 1/2" supply be large enough for both heads? I was also going to install a valve after the control valve so one head could be shut off if both were not being used at the same time.
rodsteryz is offline   Reply With Quote
Old 02-24-2016, 05:42 AM   #2
Rewards Points: 18,794
A 3/4" line would give you almost twice the flow of a 1/2" line, low flow, low pressure.
Old 02-24-2016, 06:16 AM   #3
WhatRnsdownhill's Avatar
Rewards Points: 2,220
the control valve will only give so much gpm flow regardless of supply lines to it..does the control valve have 3/4 taps on it? whats the rated gpm?
WhatRnsdownhill is offline   Reply With Quote
Old 02-24-2016, 10:48 AM   #4
Rewards Points: 3,190
Won't be ideal, but yes it will usually work just fine.
Just did this exact same thing with 1/2" lines at a beach house, and it works just fine. Yes, there is a noticeable loss of output when both are on, but it's not the end of the world.
ktkelly is offline   Reply With Quote
Old 02-24-2016, 05:54 PM   #5
Rewards Points: 1,862
I would add a another valve so you can control which is on. The rain shower or the shower head.
Old 02-24-2016, 06:40 PM   #6
I'll agree with this. Even though the boss lady said she didn't want it, I wish I had.
Shower Head (over head) dripping while using Hand Held Shower Head HTFreak Plumbing 14 09-29-2015 03:46 PM
LOW Pressure on Shower - Need head suggestions! LordX Plumbing 5 06-02-2012 01:08 AM
Rain Shower Head shakkari Plumbing 0 05-17-2010 10:17 PM
Adding a second shower head? J187 Remodeling 6 03-26-2009 11:16 AM
Weak stream of water from shower head. SuperAkuma Plumbing 3 08-01-2008 05:49 PM
