Adding Plumbing For Bar Sink - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 2 Post By rjniles
Old 10-27-2016, 09:36 AM   #1
Rewards Points: 58
Adding plumbing for bar sink
We added a sink where there is no existing plumbing. I need to run hot/cold water lines and a drain. There will be nothing in wall it will all go through the floor. Any tips or suggestions on the process before I get started? I assume since its kitchen related I am going to use a 1 1/2 down pipe with a trap and just regular 1/2" lines for the water.
dman535 is offline   Reply With Quote
Old 10-27-2016, 10:10 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Re: Adding plumbing for bar sink
Make sure that the drain thru the floor is not an S trap.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 10-27-2016, 10:28 AM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,734
You'll need a vent also... that can't go down thru the floor....
MTN REMODEL LLC is online now   Reply With Quote
Old 10-27-2016, 10:35 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Actually it can. Siamese vent.
http://www.familyhandyman.com/kitche...-sink/view-all
HitLines and MTN REMODEL LLC like this.
Old 10-27-2016, 11:17 AM   #5
Rewards Points: 58
The cabinet is 16 wide by 23 deep - so not a ton of room. I assume I need a P trap and not an S trap?
Will have to get creative with the vent.
Old 10-27-2016, 11:24 AM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
For a bar sink I would use an AAV (Air admittance valve).
Old 10-27-2016, 11:25 AM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 170
Depending on TN. code, you could possibly use an auto air vent. If not then your option is the island vent rj linked to.
In most cases sinks require a 2" drain with a cleanout. The trap arm and trap will be 1.5"
Tie the drain into an existing line that is sized properly to handle the new fixture loading- minimum 2". When making this connection, use the proper fittings- wyes if done horizontal or a tee may be used in the vertical.
Also be careful drilling joists- don't want to weaken the floor
36" Kraus front apron sink in a 36" apron sink base - best way to cut/install? Quicksmoke Kitchen & Bath Remodeling 4 10-06-2015 11:18 AM
Adding a utility sink ponch37300 Plumbing 17 09-18-2015 03:19 PM
NEW sink and plumbing is slow draining, no overflow, pipes not clogged ymi2b Plumbing 15 09-10-2015 08:29 PM
Adding a Second Sink to Vanity MartyB Plumbing 4 08-17-2012 12:33 AM
Need help with sink plumbing profenx Plumbing 19 08-01-2010 04:35 PM
