Adding New Shower Drain To Toilet Drain? W Layout Pics - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-10-2015, 05:43 PM   #16
Rewards Points: 1,938
I'll rephrase my comment. The way it is now does not meet the IPC code. You need to start the entire thing over.
You can never drain any fixture at any time into the branch of a tee on its back. That is the first thing I see picking up the lav. If you place a wye to a shower between the toilet and its lav, you will need to vent that shower vertically.
Old 02-10-2015, 05:48 PM   #17
Rewards Points: 1,910
I'm looking at those pics again. That drain line doesn't look very deep. That fitting may not work. How deep is the 3" line below the floor surface?
Old 02-10-2015, 05:51 PM   #18
Ghost, if he uses the fitting I linked in #13 would that fix the problem with the horizontal T and allow the shower and WC to be vented by the existing lav vent?
Old 02-10-2015, 05:54 PM   #19
Rewards Points: 54
thanks for the input guys. i know its messed up and thats why im trying to get it done right.
3" line is about 5-4 inched from floor surface to pipe top surface.
BNR34RB26DETT is offline   Reply With Quote
Old 02-10-2015, 06:00 PM   #20
Plumber
TheEplumber's Avatar
Rewards Points: 254
Are you willing to move the toilet to another location?
Can you upload a floor plan of proposed fixture location so we can find an alternative vent location?
Old 02-10-2015, 06:18 PM   #21
Thats a 25 dollar fitting. Why not just start over and do it right from the start. Move the toilet position so you have room for a 3 by 2 wye and can go back with a 2 by 1.5 wye to the lav and vent. 2 inch to shower. Now we have a wet vented bath.
Old 02-10-2015, 11:19 PM   #22
Rewards Points: 2,528
Ghost would this work for him?
Fitting "A" is a San-T
Fitting "B" is a 3" Wye
Fitting "C" is a 3x3x2 Wye
Fitting "D" is a Wye or a Vent Tee and would come up inside a wall built for the shower.
Then tie the vent into that stack above the flood level of the lav? Hopefully there are no other fixtures from the above floors draining into that stack
Adding new shower drain to toilet drain? w layout pics-20150208_131104-copy_zps13bd070a.jpg
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
BNR34RB26DETT (02-11-2015)
Old 02-11-2015, 04:52 PM   #23
Rewards Points: 54
took your idea and tried to have it make sense to me. what do you guys think?
- delete the T going out of toilet into vent
- run the drain all the way to shower vent so that i can vertically vent it out
-whe in the shower drain to toilet drain
Old 02-11-2015, 08:06 PM   #24
That will work.
Vent gos out the roof right?
Old 02-11-2015, 09:49 PM   #25
Ghost...the reason he can have the Wye that I have circled flat is because its being washed by the lav correct??
Adding new shower drain to toilet drain? w layout pics-20150211_161535_zpsyeiaugww.jpg
Old 02-11-2015, 09:55 PM   #26
Under IPC the lav is wet venting the shower and the toilet. A wye is what he needs there. He needs to use a sanatary tee when he picks up his lav sink in the vertical.
He only needs 2 inch to that lav wye and shower. 1.5 inch on the lav drain from the tee in the wall.
Shower and toilet clogged droopdog7 Plumbing 16 03-11-2014 05:56 AM
Shower drain in concrete should I replace? Jpatrick Plumbing 4 02-28-2014 06:03 PM
approx cost for installing a toilet and shower drain vote4Pedro Off Topic 4 10-28-2010 07:57 PM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 02:25 AM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 08:59 AM
