Adding New Drain Into Sewer Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-10-2016, 09:27 AM   #1
Rewards Points: 126
Adding new drain into sewer line
I am installing a new water softener, originally planning to drain it into a nearby floor drain, which feeds into an ejector pit, which contains a sump pump feeding into a horizontal sewer drain. I have read recently, however, the salt water is not good for the pump. Instead, could I add a new drain onto this horizontal sewer line at the same point the sump pump joins it?
I expect it would look like this? Replace the elbow with a T (or sanitary T? or wye?) to connect the sump pump and also connect a standpipe with trap and airgap device.
Is this a good approach? Is there a better approach?
Thanks!
Adding new drain into sewer line-img_3236.jpg   Adding new drain into sewer line-img_3237.jpg   Adding new drain into sewer line-img_3237_1.jpg
garrett1812 is offline   Reply With Quote
Old 02-10-2016, 10:08 AM   #2
WhatRnsdownhill's Avatar
Rewards Points: 2,220
didnt you ask this last week and get your answers??
WhatRnsdownhill is offline   Reply With Quote
Old 02-10-2016, 10:09 AM   #3
Rewards Points: 126
No. I asked about a sink and got my answer. This is for a water softener.
Old 02-10-2016, 10:12 AM   #4
just drain it into the sink, with proper air gap and your done...salt wont hurt the pump..
Old 02-10-2016, 10:14 AM   #5
your not talking large concentrated amounts of salt water, and it will be flushed from the pump area when you use the sink and the other appliances draining into the sump...
Old 02-10-2016, 10:15 AM   #6
if you hook any trap on the exit side of the pump your just going to fill the basement with water, the pressure from the pump will just blow back out the trap you want to put in..
The Following User Says Thank You to WhatRnsdownhill For This Useful Post:
JERRYMAC (02-10-2016)
Old 02-10-2016, 10:18 AM   #7
Rewards Points: 126
Would it work if there was a check valve?
Old 02-10-2016, 10:23 AM   #8
no, your asking for trouble, but its your house....
Old 02-10-2016, 10:24 AM   #9
if your going to cut into a sewer line cut a 4 x2 Y into the main line..right by that cleanout..
Old 02-10-2016, 10:59 AM   #10
Rewards Points: 126
What would be the normal way to do this?
I cannot just cut out a segment of the sewer line and add the Y fitting in. It is constrained on both ends, so I cannot move either end to get into the fitting. Would I cut out a larger section and add the Y with unions on either side?
Old 02-10-2016, 11:08 AM   #11
they make slip couplings, no ridge on the inside, lotsa glue and work fast...wear gloves, or a no hub clamp....your choice..
ben's plumbing (02-10-2016)
Service pit for main water supply and sewer line sonnaps Plumbing 3 07-23-2015 10:54 AM
Condensate Drain line build-up and smell Easypick Plumbing 0 12-28-2012 07:46 PM
Condensate Drain line build-up and smell Easypick HVAC 0 12-27-2012 11:02 AM
Broken/cracked kitchen drain line under house joshua1978 Plumbing 4 09-14-2012 04:59 PM
Washer Drain into Sewer Line near Clean-Out brmatthews Plumbing 4 12-16-2010 12:53 PM
