Adding A Floor Drain In Concrete - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-23-2015, 07:58 AM   #1
Rewards Points: 76
Adding a floor drain in concrete
I have a garage that there is a shop is above the garage and the floor separating them is poured concrete, maybe 6-8" thick. We were talking the other day and he was asking about putting in a floor drain so he could clean the shop area easier. Guess he washes stuff in there since it's a concrete floor and said it would be nice to be able to use a squeegee the water into a floor drain.
The plumbing part would be easy, the stack is right there so the drain would be short and can a vent pretty easy. But not sure about the actual floor drain install. Obviously have to core a hole in the floor but not sure what type of drain to use and how to make it secure in the hole? So how do you plumbers add a floor drain in a situation like this?
ponch37300 is offline   Reply With Quote
Old 10-23-2015, 04:18 PM   #2
Rewards Points: 1,938
Is there anything draining into the stack below your tie in?
Old 10-23-2015, 04:23 PM   #3
Plumber
TheEplumber's Avatar
What I have done in similar cases is to core drill part way through the deck using a bit as big or bigger than the drain body. Then finish drilling through using a 3" bit to receive a 2" drain pipe.
Chip out the core piece, set the drain in the recess and raise/lower the adjustable top grade.
I used a JR Smith 2005- http://www.jrsmith.com/Floor-Drain-w...-Strainer-Head
Plastic models are also available.
Anchor in some fashion from the bottom side. Then fill the topside of the flange with a no shrink grout or some product of your choice to floor level.
The only draw back is that the floor will not have a guaranteed water tight seal..... This method is really only for WH pan drains, ect.
The Following User Says Thank You to TheEplumber For This Useful Post:
ponch37300 (10-29-2015)
Old 10-29-2015, 06:21 PM   #4
Rewards Points: 76
I was at menards today and saw a floor/shower drain similar to what Eplumber linked to. I picked one up and am going to measure what diameter hole it will need and will probably rent a 5 or 6" core bit and then a 3" core bit to drill the holes and create the "ledge" Eplumber talked about. Looks like the drain flange has some holes for anchors and I can just use some tapcons to secure it to the "ledge" and then pour some non shrinking grout to fill in around the drain.
Eplumber, any tips on chipping away the concrete for the bigger diameter hole? Just a chisel bit in my sds and go at it? So drill the 5 or 6" daimeter hole maybe 2" deep, then drill the 3" diameter hole all the way through, then chip out the concrete from the bigger hole 2 inches deep? Is that the correct procedure?
Thanks for the help.
Old 10-29-2015, 06:50 PM   #5
Plumber
Pretty much- I would chip- at an angle- from the 3" toward the larger hole's edge
Also, what about rebar or cables?
Old 10-29-2015, 09:50 PM   #6
Rewards Points: 76
I know there is rebar but not sure how deep or where. I think the concrete is about 6-8" thick. I think for the larger core 2" deep should be good enough for the drain to sit in. I wouldn't think the rebar would be that close to the surface but I don't know.
Do you know if these cheaper core bits on ebay are decent or complete garbage? A 3.5" bit for 68 bucks, http://www.ebay.com/itm/NEW-3-5-Diam...AAAOxyHE5RweC8. Here is a wet core drill for 200 bucks, http://www.ebay.com/itm/NEW-BLUEROCK...QAAOxySFJSDTGh. I'm guessing they wouldn't hold up to everyday use but I probably will only drill a handfull of holes in my life time. Renting the bits and drill will probably be around 100 bucks for the day. So I would rather just buy the 200 dollar drill and 150 or so in bits and have them to use in the future. I do have a bosch sds max but the sds max core bits aren't meant to go through rebar I don't think.
Concrete Deck Repair (BIG JOB) vector006 Concrete, Stone & Masonry 25 10-12-2013 06:07 PM
Adding concrete BirdSlapper Concrete, Stone & Masonry 14 05-01-2013 02:04 PM
Adding on to curved, stamped concrete <*(((>< Concrete, Stone & Masonry 8 04-04-2013 05:17 AM
Adding posts and beam to floor for aquarium Vincer Building & Construction 4 03-23-2011 02:47 PM
adding to concrete steps [email protected] Building & Construction 1 07-02-2008 10:29 PM
