Adding Bathroom, And Kitchenette Drain Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-27-2016, 02:06 PM   #1
Adding Bathroom, and kitchenette drain question
I live in Michigan, my home was built in 1954. I am diy'ing finishing the basement, I am at a stuck on adding drains, mostly the venting. I am considering adding the bathroom underneath the are of the kitchen, and the powder room above on the main floor. In the basement the laundry tub is less than 8 feet away. In the floor there appears to have been left a intended toilet drain that is where I would like to build the bathroom, with a vanity and shower. In theory jack hammering and adding drains isn't scary. However the venting is my concern, the house is a ranch and has vents that go through the roof, however I do not have a place to tie into in the basement.
Am I correct in thinking that if a tie into the drain in the proposed location that since the first floor is vented I will be fine, or am I wrong?
I patiently await your thoughts and recommendations.
Mml665 is offline   Reply With Quote
Old 02-27-2016, 03:05 PM   #2
Rewards Points: 2,084
I am not a pro, just have seen a lot of bathroom rough-ins. I think that you are wrong. I think that the toilet, shower, and sink all need venting, but not necessarily a home run for each through the roof. Also I think it is possible to tie in your vent line up in the attic.
John Grabowski
MrElectrician.TV
MrElectricianTV is offline   Reply With Quote
Old 02-27-2016, 03:17 PM   #3
I was considering AAV/trailer vent I believe is another term. It really isn't possible for me to run new vent pipe because the upstairs is completely renovated
toilet in garage w 3 inch drain mike1977 Remodeling 3 09-08-2014 06:37 AM
Bathroom Question TinOH Electrical 6 03-02-2011 12:03 PM
