Adding Basement Bathroom Aboveground Waste Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-25-2016, 06:04 AM   #1
Rewards Points: 76
adding basement bathroom aboveground waste line
good morning today im looking into adding a bathroom in my basment. i have a aboveground waste line that runs into septic tank. where i want to install bathroom there is no cut out for a pvc Y pipe to be added so i wanted to cut into line and add one where the toilet bowl would be. my question is how would i stop waste from comming back into basment when cutting into pvc pipe. any ideas of what i can do to block waste water from spilling all over the bsmt? i have a 4 inch waste line.
thank you
Sent from my SM-G900V using Tapatalk
charles3526 is offline   Reply With Quote
Old 05-25-2016, 06:59 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Re: adding basement bathroom aboveground waste line
Unless you have a septic tank problem there is no standing water in the line out to the tank. Unless someone flushes a toilet while you are working on the pipe.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 05-25-2016, 07:59 AM   #3
Rewards Points: 76
oh ok great and there wouldnt be any black flow from the tank back into the piping any way to check it.
Old 05-31-2016, 09:45 PM   #4
Rewards Points: 76
thanx this is what i picked up at lowes this evening. its 4inch by 4inch by 2 inch i ws gonna tie it into drain to use for saniflow toilet. my question is how much waist line do i cut off in order to get the new fitting attached?
Basement Toilet Waste Line Issue siivv Plumbing 5 06-27-2013 01:02 PM
main waste line repair in basement DKPE Plumbing 1 11-18-2012 07:22 AM
Adding a basement bathroom to septic derkbake Plumbing 0 11-16-2012 01:47 PM
Chicago Basement, adding bathroom Discotech Plumbing 9 06-25-2012 08:33 PM
Bathroom addition in attic to basement drainage tmtoddsr Plumbing 3 05-16-2011 07:21 PM
