Adding Auto Vent Under Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-15-2015, 04:58 PM   #1
Rewards Points: 60
Adding auto vent under sink
I am wanting to add an air admittance valve under my kitchen sink which currently is not vented. I did not want to pay the $160 that the plumber wanted for this job, so I am hoping somebody can walk me through this. I am looking at the Oatey sure vent AAV installation kit from Menard's.
saxsquad29 is offline   Reply With Quote
Old 09-15-2015, 05:01 PM   #2
Rewards Points: 1,938
Where the 90 is at install a tee. From the side of the tee install a trap adaptor. Then install a 4 inch piece of pipe on top of the tee and your AAV valve. Use PVC primer and PVC glue.
Old 09-15-2015, 05:35 PM   #3
Rewards Points: 60
So a sanitary tee right after the p-trap or at the 90 going down to the floor. Also, what is a trap adapter?
Old 09-15-2015, 05:41 PM   #4
Rewards Points: 582
this is a trap adapter.....does your plumbing code allow aav,,,
Old 09-15-2015, 06:58 PM   #5
You will have to remove the 90 and install a few fittings.
Old 09-15-2015, 08:16 PM   #6
Rewards Points: 60
So basically something like this drawing.
Old 09-16-2015, 12:44 PM   #7
Rewards Points: 60
This is the basic layout correct?
Old 09-16-2015, 02:38 PM   #8
yepper
Use the same plastic fittings and glue and primer. Teflon tape on the studor threaded connection so you can replace once it fails.
Old 09-17-2015, 03:07 PM   #9
Check your local building code for how high the aav can be. It looks like you've got the correct layout.
Sent from my SAMSUNG-SM-G900A using Tapatalk
paulliam1 is offline   Reply With Quote
Old 09-17-2015, 03:32 PM   #10
Rewards Points: 60
Why would there be restrictions on how high? As long as it's so many inches above the trap. You would think the higher the better?
Old 09-17-2015, 03:57 PM   #11
The engineering documents set the height above the trap they want a minimum of 4 inches. The AAV still relies on a rubber diaphragm to work if it gets coated in stuff it will no longer seal on a positive pressure and allow sewer smell into the living area.
Old 09-17-2015, 04:01 PM   #12
Rewards Points: 60
But there shouldn't be any restrictions on the max height above, right? As long as its 4" above I should be okay
Old 09-17-2015, 04:02 PM   #13
We don't have any upper height restriction under IPC. Just the 4 inch lower height.
adding an extra toilet vent - bad idea pwaterm2 Plumbing 15 02-10-2015 09:56 PM
How to vent toilet, sink and shower on vent located on different wall? luvdairish Plumbing 11 05-12-2013 02:31 PM
Adding Laundry Sink notlawd1 Plumbing 3 01-02-2013 10:15 PM
Need help re-routing kitchen sink vent Fingers Plumbing 11 10-23-2009 03:17 PM
Can I tie the sink vent into the toilet vent? domgbrown Plumbing 4 01-11-2008 05:28 PM
