Adding 2nd Water Valve - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By SeniorSitizen
Old 12-18-2017, 02:19 PM   #1
Rewards Points: 60
Adding 2nd water valve
Iím considering adding a set of water valves on the outer half of my house. Are there any negative consequences for doing this? Itís so I donít have to shut down water to the entire house when Iím working on that side of the house. Thanks in advance.
mikelee221 is offline   Reply With Quote
Old 12-18-2017, 03:14 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,246
Re: Adding 2nd water valve
Ayuh,.... Addin' ball-valves won't hurt athing, nor limit the flow,...
Old 12-18-2017, 03:35 PM   #3
Rewards Points: 6,404
If you install ball valves for that application be certain they are full bore.
akuhn235 likes this.
SeniorSitizen is offline   Reply With Quote
Old 12-18-2017, 04:13 PM   #4
I should have mentioned, if full bore is available in the size you will be installing.
Old 12-18-2017, 05:14 PM   #5
Rewards Points: 60
Thanks. How do I now if it's full bore? I'm looking at this from HD...
Also, I was thinking having the drain so I can work on soldering. I'm having issues getting all the water out, figure this would help.
https://www.homedepot.com/p/Everbilt...4-EB/205812172
Old 12-18-2017, 07:14 PM   #6
When fully open you will not see any restriction in inside diameter.
Old 12-18-2017, 07:49 PM   #7
hkstroud's Avatar
Rewards Points: 6,694
Those types of valves are called Stop and Waste valves.
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
