Add-on Bathroom Rough Plumbing Remodel - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By Ghostmaker
Old 10-14-2016, 04:32 PM   #1
Rewards Points: 6
Add-on bathroom rough plumbing remodel
I'm remodeling my 1st floor bathroom and looking for advice on the rough plumbing. There use to be a toilet at left rear of the room, and a shower in the right center. I'd like to place the new toilet where the shower previously was, and in the left rear corner we'd like to add a sink. My biggest question is about the new toilet's return line. I only have access to the joist the current return line is in and the two to the right (stairs are in the way of the joists furthest to the right). I worry about the integrity of the floor joists if I cut a hole that large through boards.
FYI this bathroom is a former back porch, so underneath the joists are about 3' gap before the outside ground.
Any suggestions to relieve this problem? Any other issues anyone thinks I'm missing?
Add-on bathroom rough plumbing remodel-img_4199.jpg   Add-on bathroom rough plumbing remodel-img_4197.jpg   Add-on bathroom rough plumbing remodel-img_4198.jpg
danfman99 is offline   Reply With Quote
Old 10-14-2016, 07:18 PM   #2
Rewards Points: 1,860
Re: Add-on bathroom rough plumbing remodel
What state /country do you live in? For code reasons. Please post a measurement of the diameter of the joist.
Old 10-18-2016, 03:50 PM   #3
Rewards Points: 6
I live in Madison, Wisconsin.
The joists are 7" tall.
Old 10-18-2016, 07:30 PM   #4
I hate to bail on you but I do not know the plumbing code there. Perhaps a UPC code plumber could help you out.
MTN REMODEL LLC likes this.
Old 10-18-2016, 07:43 PM   #5
jlhaslip's Avatar
Rewards Points: 708
It looks to me like the existing toilet drain enters the room from the doorway where the pictures are taken from.
Can it be cut off under the doorway and extended back to the end bay?
Then it will not require cutting or drill of those 2x8 joists.
The sink drain could use the existing holes to connect back into the new main run, I think.
Not sure if the vent stack would need to move, either, since I am not a Plumber and not from your area.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
70's Bathroom remodel Falconag Kitchen & Bath Remodeling 16 01-25-2012 02:40 PM
Help with bathroom remodel!!! jasongilliland Building & Construction 4 11-16-2011 06:05 PM
bathroom remodel in Chesapeake, VA mt dew Building & Construction 2 10-02-2011 07:24 AM
Noob bathroom remodel jep Kitchen & Bath Remodeling 18 11-22-2009 10:56 AM
Basement bathroom rough in plumbing ferris13 Plumbing 5 09-28-2009 10:06 AM
