Access To Replace Plumbing For Roman Tub - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By corsairdriver
Old 06-25-2016, 01:46 PM   #1
Rewards Points: 12
Access to replace plumbing for Roman Tub
I have a Roman tub and need to replace some, if not all, of the plumbing for the hot and cold water (valves, faucets, etc.). I have removed the access panel/skirt for the pump (which was attached with screws and then caulked on all sides), and can see the plumbing, but cannot get my hands and tools into the narrow space to it to remove and replace. The cultured panel/skirt which needs to be removed was attached to the wood frame in several places with what appears to be joint compound. Any suggestions on removing, loosening, cutting or breaking the joint compound without breaking the cultured marble? (Getting access through the floor wouldn't work, as the space between the plumbing and the panel/skirt is too narrow for tools without removing the panel.) Thanks in advance for any help.
Access to replace plumbing for Roman Tub-dsc05112.jpg   Access to replace plumbing for Roman Tub-dsc05116.jpg
corsairdriver is offline   Reply With Quote
Old 06-25-2016, 03:19 PM   #2
Rewards Points: 12
Re: Access to replace plumbing for Roman Tub
Broke off a piece of the compound used to attach the cultured marble panel to the wood frame - it isn't joint compound so I'm thinking now it is globs of silicone caulk. Same question though - any suggestions on softening, cutting, or otherwise removing it so I can remove the panel. Assuming I can get it off in one place, I will drill holes and use screws to reattach so there is permanent access to the plumbing as well as the pump.
Old 06-26-2016, 01:26 AM   #3
Rewards Points: 3,008
I suggest that you search on "Silicone Solvent"
At http://homeguides.sfgate.com/removin...due-28359.html
it is stated:
"No solvent dissolves silicone caulk, so you won't find a chemical agent in the hardware store that will allow you to wipe away the caulk after brushing it on. Mineral spirits will soften it, but you'll probably have to accomplish the bulk of the removal by cutting the caulk with a sharp knife and pulling it off with pliers."
and
"Removing silicone caulk residue effectively is a two- or three-part process. Softening the residue by prolonged exposure to mineral spirits loosens its bond with the substrate. Leaving one or several rags soaked with the solvent in contact with the caulk for several hours is the best way to accomplish this. "
FrodoOne is offline   Reply With Quote
The Following User Says Thank You to FrodoOne For This Useful Post:
corsairdriver (06-26-2016)
Old 06-26-2016, 05:48 AM   #4
Rewards Points: 12
Thanks, FrodoOne - will give this a try and post the results. Will take a few days to get to all the silicone and I am traveling a couple of days this week, so likely won't know results until next weekend. Thanks again for the suggestion.
Old 06-26-2016, 09:13 AM   #5
Rewards Points: 1,486
Hopefully the curve panel wasn't glued, but assume it was and be careful. Long thin blade on those razor cutters can get under the joint and cut the silicon/joint filler. Vinegar can clean silicon, but recommend not scraping with razor. Try plastic scrapers but very carefully. The curved panel is probably solid surface or acrylic on curved base and will scratch very easily.
carpdad is offline   Reply With Quote
The Following User Says Thank You to carpdad For This Useful Post:
Old 06-26-2016, 02:31 PM   #6
Rewards Points: 12
Thanks, carpdad - will be trying mineral spirits and/or some type of silicone adhesive remover. Since I have vinegar handy, will give it a try first. Have used a razor cutter to remove the caulk around the panel, but the back of the panel is rock solid. Thanks again.
Old 06-30-2016, 04:25 PM   #7
Rewards Points: 12
Success - Used "Re-Mov™ Adhesive and Silicone Remover" to loosen the panel from the adhesive substance - worked great and the second panel is off, allowing access to the plumbing. (Website is http://www.re-mov.com/products-Adhes...e-Remover.html - 8oz. bottle was $15 retail.) I will reattach the panel with decorative screws to allow easy future access to the plumbing - don't know why the installers didn't do that in the first place. Thanks again FrodoOne and carpdad for the suggestions.
FrodoOne likes this.
Old 07-01-2016, 06:15 AM   #8
Can you come back with the list of active agents on the bottle? Sounds great but I just want to check if tape remover I have is same or different, before I spend the money?
Old 07-01-2016, 06:41 AM   #9
Rewards Points: 12
carpdad -bottle does not have active ingredients, but per company website active agents are as follow:
  • Aliphatic hydrocarbon ~97%
  • Aromatic hydrocarbon < 1%
  • Wetting agents (proprietary) <3%
The MSDS shows solvent as the Aliphatic hydrocarbon ~97% by weight. Stoddard
Hope this helps.
Old 07-01-2016, 09:38 AM   #10
Hope this helps.
That is a really nice "cop out" by the manufacturers of the product that you have used.
The most simple "Aliphatic hydrocarbon" is methane - followed by ethane, propane and on and on through a hydrocarbon chain of molecules.
In other words, they are, if liquid, (hydrocarbon) "Mineral Spirits" - like "Dry Cleaning Fluid" - or mineral turpentine etc.
carpdad (07-02-2016)
Way to remove and replace a tub without access to the back? Chris Sweeney Plumbing 8 06-08-2013 10:34 PM
Replacing the plumbing in the slab teri7513 Plumbing 7 10-28-2012 09:59 AM
Replace the plumbing in an old, 1700 sq.', 'slightly blighted' home new2restoration Plumbing 1 10-22-2012 05:40 AM
How do I replace the plumbing in my tub/shower? Alix Plumbing 5 06-02-2011 07:58 PM
access panels for plumbing Michaela521 Plumbing 3 04-10-2006 04:26 PM
