Access Panel Needed? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-20-2016, 09:46 PM   #1
Rewards Points: 523
To change over a 1970's 3-knob shower fitting to a single handle fitting, would access from the backside of the wall be needed, or can all the work be done from the tub side. I'm working in the room on the backside of the tub and was thinking I'd add an access panel now if needed. It won't be very easy later on.
LarryJ-nova is offline   Reply With Quote
Old 07-21-2016, 06:52 AM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,596
Re: Access Panel Needed?
If the wall is gutted in the bathroom all the work can be done from that side.
The Following User Says Thank You to joed For This Useful Post:
LarryJ-nova (07-21-2016)
Old 07-21-2016, 07:14 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Having access from the rear is always a plus. Replacement of valve or maintenance.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
access panel preventing basement bath conversion? rook81styles Remodeling 23 10-16-2014 04:42 PM
Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes kalus Electrical 22 03-23-2012 02:09 AM
new sub panel BlueBSH Electrical 11 01-22-2012 08:28 AM
Installing an access panel in a Fiberglass Tub plou Plumbing 12 09-12-2009 08:02 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
