Absolutely No Cold Water In Entire House... - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree6Likes
Old 08-10-2016, 04:24 PM   #16
Tizzer's Avatar
Rewards Points: 148
Re: Absolutely no cold water in entire house...
Not being disrespectful or anything TSlater, but what are you in this? You there to fix the problem, a resident there, what?
If this place has been leaking water for some time I'm thinking mold issues and people will get sick.
That leak you mentioned in the middle of the ceiling, can you open that up?
Too simple an idea, but has anyone checked individual faucet/toilet/shower shut-off valves that may be off?
Tizzer is offline   Reply With Quote
The Following User Says Thank You to Tizzer For This Useful Post:
Gymschu (08-10-2016)
Old 08-10-2016, 04:34 PM   #17
Oso954's Avatar
Rewards Points: 1,594
It's now used for transitional housing for people getting out of prison or really any bad situation.
A house not owned by the occupant(s) and with multiple tenants is not a DIY plumbing repair situation.
You should be complaining to the organization that is running the place to get it fixed ASAP.
In many places it is not sufficient to provide just one water supply, both hot and cold water are required for the building to be considered habitable. If the organization doesn't take action, I would start complaining to the building dept and/or the health dept.
In my area, they can red tag the buiding if the repairs are not made in a timely fashion.
Gymschu likes this.
Oso954 is online now   Reply With Quote
Old 08-10-2016, 07:17 PM   #18
Rewards Points: 4,700
Sometimes the people in charge are so uncaring you can't complain. But, you can complain anonymously to a local building dept. Best in writing.
If they do linen, the very hot water may be to keep bed bugs at bay in the washer(s), although it is unsafe. People bring the bugs with their belongings.
I understand the desire to DIY. Possibly the guys here are constrained regarding expert advice if it's not exactly a proper situation.
I'm no expert, but some water heaters have two thermostats.
http://homeguides.sfgate.com/set-upp...ers-35162.html
Nik333 is offline   Reply With Quote
Old 08-10-2016, 10:51 PM   #19
Rewards Points: 24
I'm a temp resident. Long story. Yes there is a strong mold smell in the basement. No I didn't check any of those valves, but I will.
TSlater127 is offline   Reply With Quote
Old 08-10-2016, 10:59 PM   #20
Rewards Points: 24
I just got here, but I immediately brought it to the owner attention. She acted like she had no clue and was yelling "why didn't anyone bring this to my attention before". I spoke to a couple long time residents and they said she's been told many times, but doesn't care or want to put any money into the home.
She gives you this nice talk about how she wants to help people transition into better places. That she wants to help in anyway. But it's all complete bullshyt. She take advantage of these people because they don't have many options. So she over charges rent and lets the people in the house run the house.
If this place was ever inspected it would have numerous violations and be shut down. I want to call and report her, but I also don't want anyone put out on the street. Unless, if she had to provide rooms like motels until it was fixed. IDK
Old 08-10-2016, 11:02 PM   #21
Rewards Points: 24
Yeah it had two.... didn't help, nuts.
Yeah the washer and dryer both don't work. I want to complain I just want to make sure no one will be out on the street. Yes bedbugs are always a issue in places like this.
Old 08-11-2016, 08:03 AM   #22
Super Moderator
Gymschu's Avatar
Rewards Points: 506
At this point, you need someone qualified to come in and take a look, that is, if someone is willing to come based on what sounds like a near disastrous situation. Even if you figure out why there is no cold water and can make a fix, you will still need to test that water for lead, etc. if you want everyone staying there to remain in good health. All of us on here like to DIY and can direct you as best we can from the "ether", but this is just one of those times where a retired plumber or someone like that can trace down the problem in minutes and get things rolling in the right direction. Maybe even a church group of guys with home repair skills could take a look.
Nik333 likes this.
"In the heat of battle, my father wove a tapestry of obscenity........."
Gymschu is online now   Reply With Quote
Old 08-11-2016, 08:43 AM   #23
Rewards Points: 24
I hear ya man. I was just trying to find out if it possibly a quick fix or something dumb that someone did that i could undo. Yeah I have a buddy stopping by, but he's busy as hell... Honestly, It's 99 degrees out and I have no AC or cold water... and I'm on the 3rd floor!
Gymschu likes this.
Old 08-11-2016, 08:44 AM   #24
Rewards Points: 24
thanks for all the suggestions guys.
Nik333 likes this.
Old 08-11-2016, 09:51 PM   #25
Rewards Points: 382
Might be worth going and checking all of the shutoff valves you can find, if you haven't already. Maybe a disgruntled resident turned them off.
fa_f3_20 is offline   Reply With Quote
Old 08-12-2016, 06:49 AM   #26
Super Moderator
joed's Avatar
Rewards Points: 31,578
You need to trace the pipes. Find where the feed to the water heater branches and see where it goes after that. Since you have hot water you know the cold is at least getting that far.
Find where it feeds the working toilet and see where it branches after that.
Old 08-12-2016, 02:46 PM   #27
I was thinking about this thread & wondered why the many similar owners don't put in a separate water heater to keep laundry water @ 160 degrees for bedbugs & the like? Wouldn't that save in the long run on heating bills & prevent corrosion of pipes from condensation? Rather than assume the liability of burning someone badly & the cost of heating all the water?
Just an idle question.
Gymschu likes this.
Old 08-12-2016, 06:24 PM   #28
Super Moderator
joed's Avatar
If you have current code compliant temp valves no one will be burnt in the tub or shower. Sinks are less likely.
The Following User Says Thank You to joed For This Useful Post:
Nik333 (08-13-2016)
Tags
leak in basement , no cold water
Weird shower/tub faucet handle and water flow problem daluu Plumbing 1 01-19-2014 09:08 AM
Trickle of Cold Water Pioneer Bathtub Faucet egawrons Plumbing 0 10-25-2012 11:24 AM
Only hot or cold water DiyPadawan Plumbing 8 10-20-2010 08:13 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
