Abs/pvc? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-07-2016, 04:34 PM   #1
Rewards Points: 610
Abs/pvc?
Hi everyone..long story short..I am believe that ABS DW piping is required for drainage above grade and that PVC Drainage waste pipe is approved for below grade in Ontario Canada AND that ABS can also be used below grade. I have purchased PVC for new bathroom install in basement but when I went to buy additional fittings was told that ABS is required below grade inside a dwelling and that PVC was only used under ground outside a dwelling.
I would appreciate some input from the real plumbers out there.
THANKS!
techpappy is offline   Reply With Quote
Old 02-07-2016, 05:44 PM   #2
WhatRnsdownhill's Avatar
Rewards Points: 2,220
I dont know what is code in canada, but a quick phone call to your local building dept would answer that...
WhatRnsdownhill is offline   Reply With Quote
The Following User Says Thank You to WhatRnsdownhill For This Useful Post:
joecaption (02-07-2016)
Old 02-07-2016, 05:55 PM   #3
Rewards Points: 18,808
Just would make no since there both approve above and below grade in the US.
Just depends on what's avalable in your area.
I have not seen ABS in any box stores in at least 10 years, only PVC.
No reason, both would work, it is what it is.
Old 02-07-2016, 06:00 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 812
The only time I see ABS is in mobile homes.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
Old 02-07-2016, 06:15 PM   #5
All depends on what your local codes dictate.
There is no logic in using both ABS and PVC, use one or the other depending on what they approve.
Old 02-07-2016, 06:30 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 186
You need to get out more. Perhaps out west where it's a comon product
Old 02-07-2016, 06:56 PM   #7
I've worked on house in this area for 15 years and have never seen it except in mobile homes.
No local HD, Lowes, or local real plumbing supply even stocks it.
Old 02-07-2016, 07:01 PM   #8
Rewards Points: 610
Thanks to all of you. I will double check tomorrow. I think either is OK here.
GO BRONCOS!
Old 02-07-2016, 10:16 PM   #9
Plumber
Rewards Points: 186
Like I said- you need to get around some. I've been installing it for 30+ yrs.
Commercial, residential and industrial. Sizes 1.5"- 6"
Our suppliers stock both ABS, PVC DWV and sch 40 PVC. Right now I believe DWV PVC is more economical.
Also check and see if your area approves one step PVC glue. It speeds up the glue process by eliminating the primer.
Old 02-08-2016, 01:23 AM   #10
Rewards Points: 610
Yeah..Thanks EPlumber..I will look for the one step. I will be checking on local codes (I'm actually in a small town 3 hrs outside Toronto so rather than coming up with another version they have likely adopted the Ontario Plumbing Code. Thanks again
P.S. New grandson being delivered later today so, might not get back for a day or so.
Thanks again..Techpappy
The Following User Says Thank You to techpappy For This Useful Post:
TheEplumber (02-08-2016)
ABS/PVC to Cast Iron CanadaDan Plumbing 3 10-10-2009 12:12 PM
