ABS Pipe- Nonstandard, Loose Fitting ?? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-02-2015, 02:46 PM   #1
Rewards Points: 8
ABS pipe- nonstandard, loose fitting ??
Hello, I have a problem fitting a 1 1/2 pipe to a 1/14 pipe. I have the adapter but it is a little loose on the 1 1/4 end. It is (point) .25mm of a gap or the thickness of 5 pieces of paper. How can I make this work? Will extra glue hold at that looseness? If you fold a piece of paper in 4 and flatten it you can see how loose it is.
OK, I need to make this work because 1 1/4 inch pipe and couplers are no longer manufactured. I managed to get an adapter that was left over in a warehouse. So- cannot buy other manufacturer's adapters... ALSO I have a feeling the old 1 1/4 pipe is not standard diameter on the outside- it is in an RV. And yes, the part I got was ordered through an RV supply shop. The RV is parked- no extra vibration & there will be no pressure on the drain line. Bath sink drain so nothing but water.
Lynn345 is offline   Reply With Quote
Old 05-02-2015, 03:02 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
you have to use the same type of pipe for adapters from one size of pipe to another to fit and the proper adapters for that type of pipe.
you say this is a drain; are you sure it isn't a compression fitting? If so, the pipe is different than glued PVC. Many drains use compression fittings at the sink/shower/whatever. Where in the drain system is this issue?
and 1 1/4" of what kind of pipe isn't produced any longer? I just took a look on Google and found it all over the place.
Old 05-02-2015, 03:10 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 892
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 05-02-2015, 03:12 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 892
Above:
Fernco coupling 1.24 to 1.5 "
http://www.amazon.com/Fernco-P1056-1.../dp/B000BQ7TAM
Any big box, plumbing supply or good hardware store
Old 05-03-2015, 01:04 PM   #5
Rewards Points: 8
thanks
Thanks!
Nap, it's ABS
RJ thanks, so I guess the gap is too big and this fitting would be better? The guy at the plumbing supply said he didn't trust those fittings...
Old 05-03-2015, 01:15 PM   #6
nap
You talking to me?
nap's Avatar
Originally Posted by Lynn345 View Post
Thanks!
Nap, it's ABS
I suspect the issue is the type of coupling. I have had no problems sourcing any of the fittings I have required.
but anyway:
fernco fitttings are commonly used by professional plumbers everywhere with confidence.
Old 05-03-2015, 03:14 PM   #7
Rewards Points: 8
thanks
Thanks Nap, I just got advice on another forum to use this;
Schedule 40 ABS Fitting - Female Trap Adapter - Female Hub - 1-1/2" x 1-1/4" Slip Joint Nut/Washer
and will try it. If that doesn't fit right I'll go to flexible. For some reason neither plumbing supply place could order one... I'm not a plumber, I had no idea what to order.
Old 05-03-2015, 05:19 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 258
I'm not sure where on your system is 1.25"
If it is at the sink's trap or tailpiece then the trap adapter should work.
The Fernco should work on iron pipe size lines, but as a plumber, I have seen many of them fail to hold good pipe alignment.
Can you post a picture of the connection please?
Old 05-03-2015, 05:51 PM   #9
Rewards Points: 8
pic
I hope what I ordered will work on this. The stub is 1 1/4. I know it shouldn't go down a size but I don't want to hassle with the vent pipe in the wall. Which probably isn't standard as well. Very difficult to get to If I have to cut it out. I'd have to take the whole wall out which I just put in on the other side... Can't just cut a hole...
Is this the right drainage pipe maddog1 General DIY Discussions 19 05-08-2014 08:46 AM
The drain pipe is loose at the top on the kitchen floor in the basement nvette74 Plumbing 8 12-30-2011 09:16 AM
fitting PVC pipe for water supply amakarevic Plumbing 3 08-22-2010 10:23 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 05:40 PM
Cracked PVC fitting in concrete DJupin Plumbing 6 07-29-2008 03:12 PM
