90 Turn Sewer Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-04-2016, 12:56 PM   #1
Rewards Points: 12
90 turn sewer pipe
Hello
I need to install 4" pvc sch 40 sewer pipe across two walls in the basement and need to make a 90 turn in the corner. Question is: can I just use a 4" elbow to accomplish this or is there a better way?
Bill
Backburner is offline   Reply With Quote
Old 10-04-2016, 01:46 PM   #2
Rewards Points: 1,852
Re: 90 turn sewer pipe
A street and a regular 45 is the code approved way. Or a long sweep 90 that is the same as what I mentioned.
Ghostmaker is online now   Reply With Quote
The Following User Says Thank You to Ghostmaker For This Useful Post:
Backburner (10-04-2016)
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 05:53 AM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
How Get Hand Snake To Turn 90. 1.5" Steel Pipe. TomBrooklyn Plumbing 13 03-25-2012 06:54 PM
Open Sewer pipe under sink cabinet NoName Plumbing 4 02-03-2011 09:20 AM
Sewer pipe under concrete driveway marejw Plumbing 7 12-22-2007 04:19 PM
