80 Gallon Hot Water Storage Tank? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 2 Post By KC_Jones
Old 12-02-2016, 12:05 PM   #1
Rewards Points: 267
80 gallon hot water storage tank?
Moving to a new house that has an on-demand water boiler. There are 4 zones for baseboard heat and the 5th zone goes to an 80 gallon water storage tank? I thought the whole purpose of on demand was so that standing hot water is never sitting around wasting energy? Yes I have read about a ten gallon tank being used for high demand situations.
But 80 gallons always being heated? When that water starts to cool down how does it get heated again? does it recycle through the gas boiler or is there a heating element in the tank? I definitely see that the tank has a thermostat on it. Is 80 gallons over-kill? Or should I be thrilled its there already.
windowguy is offline   Reply With Quote
Old 12-02-2016, 01:01 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,318
Re: 80 gallon hot water storage tank?
Ayuh,.... I'm guessin' yer 80 gallon tank has a heatin' coil in it that heats the DHW, as heatin' water shouldn't be used for domestic hot water,....
Old 12-02-2016, 01:48 PM   #3
Rewards Points: 267
Right.. the baseboard heat water is direct from the "boiler".. No the 80 gallon tank definitely gets fed from that boiler also. The system looks exactly like a tankless system that has a tank in between as I've seen online. but I haven't seen on with 80 gallon tank!
Old 12-02-2016, 02:58 PM   #4
Rewards Points: 454
You are thinking about this wrong. You have a boiler that also makes DHW. This is different from having an on demand water heater for your DHW. You never want to mix the 2 and for that reason you have what you have. Those 80 gallon tanks are typically super insulated and with that setup you will have tons of hot water available.
supers05 and davidlane14 like this.
KC_Jones is offline   Reply With Quote
Old 12-02-2016, 09:47 PM   #5
Rewards Points: 80
The 80 gal tank is likely your DHW storage tank. Typically you'll have 4 pipes going to that tank. However, we can check with the model of your boiler, and/or some pictures.
The DHW is only for your hot tap water not your heating system. The heating system would be completely on demand.
Cheers!
supers05 is offline   Reply With Quote
Old 12-03-2016, 03:30 AM   #6
I also think so..
davidlane14 is offline   Reply With Quote
PV Solar electricity tied directly to a DC Water Heater JStofik Green Home Improvement 26 02-25-2015 05:17 PM
how to stop drops of water at tank top receptacles? young707 Plumbing 6 08-22-2012 05:41 PM
Water storage tank gseith Plumbing 5 06-07-2011 03:40 PM
Concrete tank for solar water preheating? Badfish740 Building & Construction 5 03-09-2010 08:20 PM
Nightmare water tank job Marvin Gardens Plumbing 6 11-04-2008 11:09 AM
