45's Between Trap And Wall? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-27-2015, 06:54 PM   #1
Rewards Points: 18
45's between trap and wall?
Hi there-
I am installing new cabinets in my kitchen. I want to use an ikea sink cab that has the drawer for compost/trash, but my drain in the wall is a little too low and the back of the drawer will hit the trap. I am using an apron sink and the drain in very far towards the front of the cabinet so I have plenty of space to insert other pieces. I found this diagram of what I basically want to do, but its a bit old. I only need to raise the drain about 3 inches. Would it be code to use a couple 45's or 90's to raise my drain a few inches at the wall? I found a bunch of stuff about an strap, but not sure if that applies with the drain in the wall not in the floor. Thanks for any guidance you may have!
jdecker1978 is offline   Reply With Quote
Old 11-27-2015, 07:10 PM   #2
Rewards Points: 18,808
A real picture of what you have would be a big help.
Old 11-27-2015, 07:18 PM   #3
Rewards Points: 18
This is a photo using similar drawer (the actual one isn't assembled yet, its the same just wider). Seeing as the trap will be even lower than the drain, it won't work as is. Im hoping to not cut the back of the drawer apart. My drain is 2 inch past the t, but its a female 1 1/2" coming off the sanitary tee that I will hook to. The bottom of the drain is 7" from the bottom of the cabinet, and I need about 10" to clear.
Old 11-27-2015, 07:19 PM   #4
Rewards Points: 18
Not sure why the forum flipped my photo upside down. Sorry about that. Ive tried several times and orientations and every time it posts it upside down.
Old 11-27-2015, 11:47 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 186
Fixed the picture for ya.
The trap needs to be at the elevation of the tee- not above the drawer. This would be an S trap.
You can build an offset around the drawer- then drop into the trap at the tee. Or raise the tee inside the wall.
Old 11-28-2015, 08:41 AM   #6
Rewards Points: 1,866
Raise the tee in the wall.
The Following User Says Thank You to Ghostmaker For This Useful Post:
jdecker1978 (11-28-2015)
Old 11-28-2015, 08:46 AM   #7
Rewards Points: 18
Thanks! So i understand correctly, is this the offest idea if you ignore the second sink basin on the right...? Are there restrictions to what i can use as far as the 90's in the line(assuming im replacing that t with a 90). And i shouldnt have issues with gas smell?
Old 11-28-2015, 08:50 AM   #8
Rewards Points: 18
So this is the idea?
Old 11-28-2015, 10:11 AM   #9
That you can do. The original picture you raised the trap above the vent that you can't do. But a bit of modification you could replace the top 90 that picked up the trap with a sanitary tee and install a AAV off the top of that tee. AAV Air Admittance Valve.
http://www.homedepot.com/p/Oatey-Sur...9016/100201861
Old 11-28-2015, 10:32 AM   #10
Rewards Points: 18
So just to make sure I have this right-
If I do an offset drain I still need an AAV? I did read from the original poster of the last photo I posted that his sink drained slow. People seemed to think this was because of the long horizontal between the drain and the trap. If I did an offset drain (this makes much more sense over the drawer) do I still need an AAV to have it drain properly? If so would I put a sanitary tee at the end of the long horizontal, going down to ptrap and up to AAV?
Sorry for my ignorance here! I really appreciate your help.
Old 11-28-2015, 03:04 PM   #11
Your first drawing you put up is what Im referring to. Put the san tee and AAV at section B
Old 11-28-2015, 04:56 PM   #12
Rewards Points: 18
Ill try to make this my last question. Do you see an advantage to that versus the offset drain in the last photo i posted? Thank you!
Old 11-28-2015, 07:51 PM   #13
A bit less amateurish.
Tags
drain , ptrap , raise drain , strap
HELP - Broken Sink Trap Fitting NIGHTMARE! Steve Sr Plumbing 17 03-10-2013 05:45 PM
kitchen wall drain outlet higher than trap arm Druidia Plumbing 24 10-13-2011 12:39 PM
P Trap to wall waste Drain - Newbie plumber homeboyslim Plumbing 1 05-09-2011 04:02 PM
Brass p trap and ABS wall drain nitting Plumbing 4 04-21-2011 09:06 PM
Leaky wall drain/P trap connection, help please! MrSandman Plumbing 5 10-18-2010 06:10 PM
