4" Cast Iron - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-22-2016, 10:49 PM   #1
Rewards Points: 119
4" cast iron
Hi All
I have a cast iron snapping tool, I have used it on a straight pipe successfully
My question is can it be used to snap a 4" cast iron elbow just behind the bell.
RH913RH is offline   Reply With Quote
Old 05-23-2016, 04:51 PM   #2
Rewards Points: 1,938
Re: 4" cast iron
Try it but do not forget to rotate as you snap.
The Following User Says Thank You to Ghostmaker For This Useful Post:
RH913RH (05-23-2016)
where to buy a short length of 4" cast iron waste pipe diy888 Plumbing 12 03-14-2015 06:50 AM
4" cast iron to pvc hub jonnyz Plumbing 11 01-01-2013 10:02 PM
Using a pipe hub donut to join 3" PVC to 4" Cast iron pipe. pazmocars Plumbing 1 12-24-2010 08:37 PM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 10:21 AM
working with cast iron ericadami Plumbing 9 11-30-2008 12:45 PM
