3" Cast Iron To 2" Pvc Under Concrete. Which Adapter? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree3Likes
  • 2 Post By TheEplumber
  • 1 Post By rferoni
Old 02-14-2017, 10:12 AM   #1
Rewards Points: 151
3" cast iron to 2" pvc under concrete. Which adapter?
Hello all,
Posted almost a year ago about my basement shower. Well finally got it framed out and water supply plumbed. I'm literally in the process of connecting 2" pvc drain to the 3" cast. Which adapter do I use?
I'm only tying in to one end of the cast iron. I did not have to cut out a section as the shower drain ties in to the main somewhere down the line.
I originally bought a fernco coupling that slips over the cast and the pvc and then is tightened down by two stainless steel bands(I call them hose clamps). I now see there is a 'bushing' style adapter also. It is pounded inside the cast and then the pvc is pushed into it. Is one preferred over the other? Both are acceptable to be buried so it just seems a matter of preference.
Thanks,
Ron
rferoni is offline   Reply With Quote
Old 02-14-2017, 10:30 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 13,138
Re: 3" cast iron to 2" pvc under concrete. Which adapter?
Ferncos are well proven. I get a bit worried with the non-shielded units when you are burying them. They can get pretty beat up.
With the bushing, it might be a bit more "robust" in that it is inside the cast iron.
The reality is that you can use both if you want.
Old 02-14-2017, 10:40 AM   #3
Rewards Points: 6,286
I've always felt the bushing would be a smoother transition with the pvc extending into the cast what ever distance is preferred or allowed rather than having a 90 turn of water and debris at a fernco joint.
SeniorSitizen is offline   Reply With Quote
Old 02-14-2017, 10:44 AM   #4
Rewards Points: 151
Thanks for the replies.
SeniorSitizen, what do you mean by 90*? It is a horizontal connection. One can shove the smaller pipe in as much as you want using either adapter.
Ron
Old 02-14-2017, 10:47 AM   #5
Ron
Yes, my error.
Old 02-14-2017, 11:50 AM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 240
All the model codes I have worked under do not allow ferncos inside a building.
If you have the cast iron hub, then go with the rubber insert doughnut. If no hub is there, then use a shielded no hub coupling designed for CIxPL. Use a plastic bushing to get down to 2"
Sent from my XT1650 using Tapatalk
bob22 and Windows on Wash like this.
Old 02-14-2017, 04:25 PM   #7
Rewards Points: 1,926
The mans right it's your house so do it correctly all rubber ferncos do not hold pipe alignment and present a lot of jagged edges to snare junk.
The band name he is looking for is proflex or mission brand.
Old 02-14-2017, 06:19 PM   #8
Rewards Points: 151
Well. Wished I would have saw these posts earlier. I went ahead with the fernco coupler(box stores didn't have 3" by 2" donut) and even buried it in sand. Then I saw EPlumbers post. So I unburied it and got the right stuff and redid it. Only cost me a 2" ptrap.
TheEplumber likes this.
Old 02-14-2017, 10:05 PM   #9
Plumber
Rewards Points: 240
Glad you went the extra step. Good luck with the shower and we're here for ya
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 11:19 AM
Cast iron vs mod/cons rickmay HVAC 46 10-21-2011 03:42 PM
cast iron or pvc treerat Plumbing 1 03-29-2011 06:38 AM
Help with Cast Iron Material Tester Plumbing 2 10-25-2007 10:58 AM
