3/8 Copper Tube Longer Than 100 Ft? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-02-2016, 10:05 AM   #1
Rewards Points: 72
I've been looking around for some longer lengths of copper tube. I can't seem to find anybody who sells a coil longer than 100'. For the project I have in mind that would be stretching it and I'd rather have more wiggle room. Does anyone have a supplier of regular 3/8 copper that could get it longer? I haven't found any on Google.
Hoek is offline   Reply With Quote
Old 04-02-2016, 10:22 AM   #2
Rewards Points: 18,764
Re: 3/8 Copper Tube Longer Than 100 Ft?
What's the project?
Old 04-02-2016, 11:07 AM   #3
What's the project? Is there any reason why you can't solder/braze on the extra length?
hvac benny is offline   Reply With Quote
Old 04-02-2016, 12:45 PM   #4
An old Tradesmen
Rewards Points: 9,206
With the exception of instrument copper tubing(available in 500' coils). I think you'll find that 100' is the max length its sold by.
You may be able to special order it from a factory/manufacturer though.
Old 04-02-2016, 12:46 PM   #5
Rewards Points: 258
just solder or braze to the length you need
woodchopper65 is offline   Reply With Quote
Old 04-03-2016, 07:50 AM   #6
Rewards Points: 3,264
Are you sure you want to run 3/8" plumbing that far? There would be pressure problems at the far end.
They make the coils that long for convenience of manufacture and handling where it is still the intent that the tube will be cut into short lengths.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
question about replacing knob and tube ocelli77 Electrical 2 11-24-2012 07:30 AM
Angle valve on 1/2" copper tube for bathroom sink Bigb142 Plumbing 4 12-10-2011 08:24 AM
Insulating wall when running Copper Tube lines to an exposed wall face scubber Plumbing 2 04-13-2009 09:54 AM
Copper pipe size question greymous Plumbing 18 01-30-2009 04:02 PM
Debate - Pex vs Copper sandy2982 Plumbing 13 04-10-2008 10:47 PM
