Is A 3/4" Sillcock Really 3/4" Inner? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-18-2015, 04:48 PM   #1
Rewards Points: 89
Is a 3/4" sillcock really 3/4" inner?
Hi, I have a 1/2" non-freeze sillcock that I installed myself a couple of years ago. The other day it dawned on me that if I replaced it, along with the six feet of 1/2" copper that feeds it with 3/4" I'd get better flow from the 1" garden hose. Even my small hoses are 5/8".
HD didn't have any 3/4" sillcocks ... just combinations that play games with inner/outer threads to support both hookups.
Does anyone know if the typical 3/4" sillcock will give me better flow than a 1/2", or are they both the same sized plumbing inside?
Thank you.
tbeaulieu is offline   Reply With Quote
Old 06-18-2015, 05:53 PM   #2
Oso954's Avatar
Rewards Points: 1,902
Look into the hose attachment. The point of greatest restriction is often (but not always) the hole where the water exits the valve body into the hose.
Here is a pic. See the smaller hole that is set back inside the hose casting. With the same size supply pipe, the larger this hole is generally indicates the better the flow.
Oso954 is offline   Reply With Quote
Old 06-18-2015, 06:16 PM   #3
Rewards Points: 89
Thanks. They don't carry these at the box stores though, so I'm unable to measure them. Need to verify before ordering somehow...
Old 06-18-2015, 06:45 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 290
I don't think you'll find any difference until you upgrade to a high end industrial/commercial model- and it will probably cost you dearly....
The Following User Says Thank You to TheEplumber For This Useful Post:
tylernt (06-19-2015)
Well, Air in Line, and the Sillcock the culprit? Doc R Plumbing 1 06-10-2014 07:50 PM
Help diagnosing leak under sillcock NealInTexas Plumbing 11 05-26-2013 11:11 AM
Copper Sillcock Broke off inside Brick Wall- How to remove? amodoko Plumbing 4 11-30-2012 03:30 AM
Help needed with soldering a frost proof sillcock in amodoko Plumbing 6 10-07-2012 08:49 PM
Can you solder within an inch of a closed shut off valve? amodoko Plumbing 17 08-16-2012 12:29 AM
