3/4 Inch Main Line - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 2 Post By joed
Old 03-16-2018, 12:04 PM   #1
Rewards Points: 2,264
3/4 inch main line
Would using a 3/4 inch main line for the hot and cold that loops back to itself with 1/2" branches off of it provide better flow to each fixture?
Say if someone flushes the toilet while another is in the shower, right now the shower gets hotter because the toilet uses the cold water. would doing a loop with the hot and cold line help this as water would come from both both directions. so the first fixture in the line would not get all the water.
Hope the description makes some sense.
mae-ling is offline   Reply With Quote
Old 03-16-2018, 12:28 PM   #2
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,704
Re: 3/4 inch main line
Originally Posted by mae-ling View Post
Would using a 3/4 inch main line for the hot and cold manifolds
... with 1/2" branches off ... to each fixture?
Sounds like you're doing fine.
TarheelTerp is online now   Reply With Quote
The Following User Says Thank You to TarheelTerp For This Useful Post:
mae-ling (03-16-2018)
Old 03-16-2018, 12:57 PM   #3
Unfortunately there is not room to put in a true manifold system.
Old 03-16-2018, 01:44 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 32,020
That is what a pressure balance shower valve is for.
York v45 and akuhn235 like this.
The Following 2 Users Say Thank You to joed For This Useful Post:
Ghostmaker (03-16-2018), York v45 (03-18-2018)
Old 03-17-2018, 08:26 PM   #5
Rewards Points: 126
What Joed said ^^^ you need a pressure balance cartridge/valve in your shower
akuhn235 is offline   Reply With Quote
main supply line needs to be replaced - your thoughts NABRIL Plumbing 7 03-16-2014 07:42 PM
Main Sewer line is disjointed and offset cprao Plumbing 33 12-26-2013 07:56 PM
Washing machine to main line Robv81 Plumbing 8 12-24-2013 09:09 PM
Main water line, meter to house ckc Plumbing 15 09-28-2012 09:15 PM
Main Sewer Line repair Unregistered Plumbing 3 03-14-2005 07:10 AM
