2 Houses Same Well - One Has Brown Water Other Is Clear - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree4Likes
  • 1 Post By lenaitch
  • 1 Post By SeniorSitizen
  • 1 Post By Mystriss
Old 03-24-2020, 04:52 PM   #1
Rewards Points: 44
2 Houses Same Well - One Has Brown Water Other is Clear
Any suggestions on what I can check?
Have 2 houses connected to the same well and pressure tank. Other house has brown water at all faucets and in toilets (not h/w heater related). My house still has clear water.
JBG420 is offline   Reply With Quote
Old 03-24-2020, 05:00 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 9,954
Re: 2 Houses Same Well - One Has Brown Water Other is Clear
Piping in both...?
Old 03-24-2020, 05:05 PM   #3
Mystriss's Avatar
Rewards Points: 5,542
I'd say pipes too, but maybe one has filter other doesn't?
(I'm not a professional, just a homeowner who dabbles in a bit of everything DIY)
Mystriss is offline   Reply With Quote
Old 03-24-2020, 05:54 PM   #4
Rewards Points: 44
Ok update, we ALL have brown water. Father in law is a civil engineer. Said we have an excess of ground water/runoff right now, turn a hose on and let it run an hour?
Old 03-24-2020, 06:21 PM   #5
Usually Confused
lenaitch's Avatar
Rewards Points: 1,276
It sounds like a shallow dug well. They are susceptible to all sorts of surface impacts. If it is sediment, running the water might help. Sharing a pressure tank suggests you are in an area that doesn't experience freezing. A system water filter as close the well as possible might help, or one at each house.
_________________________________________
Pro patria
lenaitch is offline   Reply With Quote
Old 03-25-2020, 06:58 AM   #6
Rewards Points: 44
Appreciate that. The pressure tank is also underground - we definitely get freezing weather here in PA. Water has definitely cleared up overnight but is still a bit cloudy.
Old 03-25-2020, 07:56 AM   #7
Usually Confused
lenaitch's Avatar
I've seen shared private water systems but nothing like you describe with a buried external pressure tank so I'm kinda out. My filter suggest still stands. With a shallow wells, you are susceptible to contamination from agriculture, road salt, etc. as well as sediment - I would be testing it regularly.
Windows on Wash likes this.
Pro patria
Old 03-25-2020, 08:09 AM   #8
Rewards Points: 44
Got it, thanks. To clarify, the pressure tank is underground in a cement "room" so I guess that is what keeps it from freezing?
This morning both houses have clear water.
Both houses were built in 1987. Maybe code was different then, but both houses share a well and pressure tank.
I would like to get the water tested but seems all the labs are shutdown around here due to coronavirus.
Thanks all.
Old 03-25-2020, 09:39 AM   #9
Rewards Points: 4,300
Thanks all.
Our well was drilled in 1983 and wasn't allowed in a pit.
If that dirty water well was mine I would not drink 1 sip before the well was at least sanitized and then probably boil until a lab could test.
lenaitch likes this.
Old 03-25-2020, 03:02 PM   #10
Usually Confused
lenaitch's Avatar
There are procedures available online on how to shock (sanitize) a well with bleach. The only one I have ever focused on is for drilled wells but assume there is something similar for shallow wells.
Interesting that they would put the workings in a concrete pit in the ground; I've not seen that before. I have only seen a shared well on a pair of permanent; i.e. non-seasonal dwellings, once. It could make for some interesting maintenance, liability, and cost-sharing discussions between neighbours.
SeniorSitizen likes this.
Pro patria
Old 03-26-2020, 01:50 AM   #11
Mystriss's Avatar
Maybe a long shot, but our water came up brown after the big earthquake. Took a day to settle out. It's never done it before and hasn't since, even with all the aftershocks.
