1960 Eljer Toilet With Leaky “triple Seal Ball” Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-25-2016, 06:30 PM   #1
Hack
P1h3r1e3d13's Avatar
Question
1960 Eljer toilet with leaky “triple seal ball” valve
I've got a 1960 Eljer toilet with an old school, Radiator Specialty, triple seal ball. The tank looks just like the one in this post (except dirtier).
The ball leaks pretty badly, the mechanism is a hassle to try to align, and the lever takes a lot of force to flush.
Can this be converted to a newer style of flush valve? Maybe like an Eljer Touch Flush?
Or should I just replace the ball and clean and grease its seat?
P1h3r1e3d13 is offline   Reply With Quote
Old 01-25-2016, 06:57 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,316
Ayuh,... For under $100. bucks, put in a New toilet,...
Old 01-25-2016, 06:58 PM   #3
Hack
I didn't realize they're so cheap! But I can't. I don't own the place.
Old 01-25-2016, 06:59 PM   #4
Rewards Points: 3,492
The old post you linked to has some pretty good suggestions. Start there. I'm sure you could still fine parts for it and fix it. But why, as mentioned, new toilets aren't that expensive.
I would opt for a newer toilet bowl. Just a suggestion.
jmon is offline   Reply With Quote
Old 01-25-2016, 07:23 PM   #5
Hack
Thanks. I'm curious about the suggestion in that thread to retrofit a “Touch Flush” mechanism. I'd like to know whether that's possible.
Old 01-26-2016, 05:42 AM   #6
Bondo's Avatar
Ayuh,... Then maybe you should be callin' yer landlord,.....
If you were my tenant, that's what I'd want ya to do,....
I fix my rental house, Not the tenant,....
The Following 4 Users Say Thank You to Bondo For This Useful Post:
ben's plumbing (01-26-2016), jmon (01-26-2016), joecaption (01-26-2016), plumberinlaw (01-26-2016)
Old 01-26-2016, 07:00 AM   #7
Rewards Points: 582
eljer triple seal balls .... can still be replaced....check ace hardware ..they should have the replacement for it...couple bucks your done...
Old 01-26-2016, 07:39 AM   #8
Rewards Points: 3,438
The bracket above the ball needs careful adjustment so the ball will naturally drop straight onto the valve seat. The example the OP shows is particulary problematic because the bracket can easily get out of adjustment sideways.
If the flush level does not pull the ball straight up then the bracket will go out of adjustment sooner.
Also in the example shown, if you try to tighten the bracket too much, the ceramic tab where it attaches to the (front wall of the) toilet tank could break and that will finalize the decision on replacing the toilet.
Stick to your lawn watering schedule until it really pours. Otherwise the storm might miss and the part that gets watered last (3 days away?) will dry up.
Old 01-27-2016, 10:16 PM   #9
Hack
Yeah, all that hassle is why I want to replace the whole mechanism.
__________________________________________________ __________
Since this seems to be a real point of confusion, it's at my cousin's house. I'm trying to do him a favor.
Tags
eljer , flush , leak , tank ball , toilet
Toilet Still Leaking After Replacing Gasket, Bolts, Fill Valve, Flush Valve wheeee Plumbing 24 08-11-2017 08:57 PM
Removing anti-siphon valve from a toilet tank Chris0516 Plumbing 7 09-30-2012 05:09 PM
Leaky air valve on furnace dcam HVAC 0 11-01-2009 06:36 PM
Leaky toilet drain secutanudu Plumbing 0 08-17-2009 10:14 AM
Water Noise = Leaky Toilet? DIY_JC Plumbing 5 07-31-2008 06:35 PM
