1912 Faucet Repair - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-08-2016, 06:11 PM   #1
1912 Faucet Repair
Want to put the original sink back in my house which was my Great Grandfathers. House was built in 1912 and the old cast sink is stamped 6-14-12. The faucet handles look like a plus sign with a ball on each tip. These have a porcieln center marked H and C. I do believe that I need to remove the porcieln tops to get to the screw which holds the handles on. I can not even so much as get a razor blade started under the edge of them. The seats are good,but the rubber top-side is rotted and certain to leak. First time user of this site and think I will enjoy it. TIA
River Rat is offline   Reply With Quote
Old 02-08-2016, 06:56 PM   #2
Rewards Points: 3,412
Is there a ring around the outside center of the plus sign handle that holds the porcelain center in place and you unscrew the ring to get at the screw holding the handle on the stem?
Stick to your lawn watering schedule until it really pours. Otherwise the storm might miss and the part that gets watered last (3 days away?) will dry up.
AllanJ is online now   Reply With Quote
Old 02-08-2016, 07:08 PM   #3
No such luck. And I do not want to do anything like hot water,cold water to get expansion and contraction. If I break one then the whole thing is for nothing. Have soaked them in WD 40 for a week also. TIA
Old 02-08-2016, 08:55 PM   #4
Rewards Points: 18,962
There's only two different types, pry off or unscrews.
A picture may help.
100% sure your turning it the right way?
Guess it's just me but I would not spend the time to try and fix a faucet that old.
Most likely you could find an exact replacement you could get free parts for under warranty.
Old 02-08-2016, 08:56 PM   #5
Rewards Points: 82
Can you please upload the picture of your faucet?
cmorales is offline   Reply With Quote
Old 02-08-2016, 09:59 PM   #6
With the help of my fantastic daughter,here are the pics. My daughter says if you copy paste these links into Internet Explorer the images should appear.
Old 02-08-2016, 10:11 PM   #7
Rewards Points: 1,300
I think your daughter needs to try again. She should be able to attach photos from your (hers) computer directly to this thread
Anti-wingnut is offline   Reply With Quote
Old 02-08-2016, 10:12 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 248
No such luck- try this method
http://www.diychatroom.com/f114/how-...-posts-205921/
The Following User Says Thank You to TheEplumber For This Useful Post:
gregzoll (02-08-2016)
Old 02-08-2016, 10:25 PM   #9
Did it work this time? I think it did.
1912 Faucet Repair-20160208_214843_resized.jpg   1912 Faucet Repair-20160208_214919_resized.jpg
Old 02-08-2016, 10:47 PM   #10
Rewards Points: 6,652
Get a bigger knife. A multi-edge blade that has a knife edge, roller cleaner, works on these kind of jobs. You may have to soak the unit in a crockpot filled with water and dish washing soap, then letting them soak all day, before you can get those caps off.
The caps basically have a metal bottom on them, which can get stuck from corroding. There are places that you can get the caps from, if the metal bottom is pretty much rotted away.
http://www.oldhousejournal.com/magaz...ts/index.shtml
http://homeguides.sfgate.com/install...cet-63840.html
Faucet Depot has been online since 1996. They can help you get new caps if you need them. Also will be able to send you the correct replacement parts and instructions. If you have to redo the seats, take your time doing so. Otherwise, your work will be ruined.
http://www.faucetdepot.com/shop/Kitc...ts-208-1-7.asp
The Following User Says Thank You to gregzoll For This Useful Post:
dd57chevy (02-09-2016)
Old 02-08-2016, 10:50 PM   #11
Rewards Points: 82
Yes, you need to remove the H and C label because there is a screw behind that.
Which part do you want to replace? The Gasket?
Old 02-09-2016, 06:33 AM   #12
When you change the faucet washer, would the inside part with the coarse threads slip off and then the handle and stem slip out from the cap nut together?
(Don't pry it using one big screwdriver and an assortment of shims; you will warp the cap nut and damage the bearing at the apex where the stem comes out.)
Old 02-09-2016, 07:51 AM   #13
Getting those caps off, they may have to resort to use a single blade razor, or even a dental pick. I think that if they soak it for the day in a crock pot, to give it a "Pickle" Bath, which may help to loosen those caps.
http://www.nancylthamilton.com/techn...d-baking-soda/
"Jeweler’s pickle is neither an embalming fluid nor some strange moonshine – it’s what you use to get fire scale off soldered objects. If you work with metal and use heat, a pickle pot is essential. Basically, a pickle is simply an acidic solution that removes oxidation and flux from a piece of soldered metal. Commercial jewelry pickles are available, and many jewelers choose to use various pool chemicals as more cost-effective pickles."
Information to make the "Pickle" solution. http://www.natashalh.com/tutorial-th...welers-pickle/
Old 02-09-2016, 08:28 AM   #14
Rewards Points: 270
I have a 1910 Crane pedestal sink. I've had luck with these guys for parts. I'm not sure what brands they carry, but they have some old reproduction parts. Some of them they make themselves.
They ain't cheap, but probably worth a look.
http://deabath.com/index.html
b-boy is offline   Reply With Quote
Old 02-09-2016, 10:15 AM   #15
Rewards Points: 2,906
You should also try Kissler for parts. Kissler is a plumbing parts company that specializes in parts for old and obsolete faucets. They also have their own machine shop where they make brass parts that can't be purchased because no one else makes them anymore.
Phone Kissler at 1-800-547-7537 and ask to speak to Doug Turner (if I recall correctly) in their old parts department. Maybe e-mail him the pictures you posted and see if he knows how to remove the handles from the cartridge and if parts are still available for that faucet.
Kissler has a $250 minimum order, but if you speak to anyone in their accounts receivable department, they'll tell you who they frequently ship to in your area, and it would then just be a matter of ordering the parts from that company and waiting for them to accumulate orders worth more than $250.
Download the Kissler faucet parts catalogue from here:
www.kissler.com
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Broken Faucet Handle - Repair or Replace? [with Pictures] steadyboiler General DIY Discussions 10 09-10-2015 06:49 AM
Delta faucet leaking after repair & new parts KarenNoelle Plumbing 1 01-28-2015 07:01 AM
Delta faucet repair? kbsparky Plumbing 5 04-18-2011 06:31 PM
Moen faucet repair simonxx Plumbing 2 04-07-2009 08:22 AM
Moen 3 knob faucet repair? blue82001 Plumbing 3 06-16-2006 11:32 AM
