12" Rough Toilet Installed In A 14" Space - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-29-2016, 11:13 AM   #1
Rewards Points: 27
12" rough toilet installed in a 14" space
I recently had to remodel my power room and the toilet I purchased was a 12" rough-in and apparently space is designed for a 14" or 15"" rough-in. so now my new toilet is sitting about 4 inches from the wall.
my questions are: other then how it looks is there any issue with this set up.? Question 2 is: if the back of the toilet is sitting 4 inches away from the finished wall does it move the bowl of the toilet that much closer as well?
I have a small power room and just make it now with my knees at the opposite wall.
VinnyBags is offline   Reply With Quote
Old 03-29-2016, 11:46 AM   #2
Retired Moderator
Rewards Points: 7,174
Re: 12" rough toilet installed in a 14" space
Yes, moving the drain opening to 12" will position the toilet next to the wall--and you will regain the 4" of leg room.
One of the plumbers might know if 15" center toilets are still being made.
Toilet Rough in too far from wall donbean3320 General DIY Discussions 15 01-30-2014 02:09 PM
Why does my newly installed toilet rock back and forth? TrailerParadise Plumbing 26 06-26-2013 12:06 PM
Basement Toilet Rough In - Help atm Plumbing 3 06-06-2009 11:04 AM
Sealing the space between the toilet and the floor... pro_DIYer General DIY Discussions 4 07-11-2008 01:25 PM
Need opinion - Need help - I believe my toilet was not installed properly rdlegacy Plumbing 9 05-06-2008 05:03 PM
