1 Step Glue For All Cpvc? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-23-2016, 08:42 PM   #1
Rewards Points: 54
1 step glue for all cpvc?
I purchased the oatey flowguard 1 step cpvc glue in pic attached. Can this be used with any brand cpvc pipe and not flowguard pipe without primer? I have genova brand of pipe.
akajoe87 is offline   Reply With Quote
Old 03-24-2016, 08:59 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Re: 1 step glue for all cpvc?
Check with your AHJ (Plumbing inspector), not all locations will accept primeless cements
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 03-24-2016, 09:57 AM   #3
Rewards Points: 106
one steps are not the best, the primer cleans and softens the pipe for the glue, and the glue , solvent welds the pipe together, dipping the brush that cleans the dirt and junk from the pipe just contaminates the entire can in the one step stuff...most codes dont allow it..
goobertime is offline   Reply With Quote
Old 03-24-2016, 10:53 AM   #4
Rewards Points: 1,852
05.16.2 Solvent cementing. Joint surfaces shall be clean and free from moisture, and an approved primer shall be applied. Solvent cement, orange in color and conforming to ASTM F 493, shall be applied to all joint surfaces. The joint shall be made while the cement is wet, and in accordance with ASTM D 2846 or ASTM F 493. Solvent-cement joints shall be permitted above or below ground.Exception: A primer is not required where all of the following conditions apply:
1. The solvent cement used is third-party certified as conforming to ASTM F 493.
2. The solvent cement used is yellow in color.
3. The solvent cement is used only for joining 1/2 inch ( 12.7 mm) through 2 inch (51 mm) diameter CPVC pipe and fittings.
4. The CPVC pipe and fittings are manufactured in accordance with ASTM D 2846.
IPC allows one step for CPVC if the above is true.
Old 03-24-2016, 10:52 PM   #5
Rewards Points: 114
I always use primer with one step glue, it's helps clean and bond the pipe
Chrisathome is offline   Reply With Quote
Painting over tile glue? cavemangeorge Painting 1 02-18-2016 01:35 AM
New glue for PVC? lep Plumbing 12 09-26-2015 08:55 AM
Hang drywall vertical or horizontal nickm1024cobra Drywall & Plaster 54 03-30-2011 11:37 AM
cpvc advice on roughing in my house jimmy21 Plumbing 8 07-25-2008 07:38 PM
Wood Glue Issue gp1200r Carpentry 4 02-20-2008 11:56 AM
