1 Radiator On 2nd Floor Cold - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree3Likes
Closed Thread
Old 01-07-2017, 09:48 PM   #46
Rewards Points: 80
Re: 1 Radiator on 2nd Floor Cold
Originally Posted by Bob Sanders View Post
For steam boilers you have no choice but to open. it's law. You also must test them once a year... a pop test as well as accumulation test (you have to keep the boiler running after they pop open and record the maximum pressure the boiler hits). I've got one boiler I do which has four 2 inch relief valves. It makes a heck of a mess during an accumulation test!
I've only dealt with low pressure steam boilers and water only boilers.
Our laws are clearly different. They usually stick because if crud in them. I've cleaned them out before and 50% of the time they reseat after that. The other half, there's just too much much crud to seal, but they actually work just fine.
Cheers!
supers05 is offline
Old 01-08-2017, 02:58 AM   #47
An old Tradesmen
Rewards Points: 9,532
Which means the relief valve is buggered and needs changing anyway so the boiler SHOULD be shut down.
If these devices are exercised regularly (as they should be) through their try levers, it minimizes the chance of sticking due to long periods of non use. In Manitoba this is guarded status law (for steam boilers). A relief valve is to be exercised once every 24 hours for a low pressure boiler and once every 8 hours for a higher pressure system.
But since joetab24 is in PA USA instead of Manitoba Canada, its not done, nor is it code here.
The tech may have shut the manual valve off because the auto feed bleeds through.
So why would you want joetab24 to go without heat till Monday if his relief opens and doesn't close. Most of us try not to give advise that could cause a poster to have no heat until the next normal business day. Or call out a tech on the weekend and pay a high fee to have something fixed.
beenthere is offline
Old 01-08-2017, 05:21 AM   #48
Bob Sanders's Avatar
Rewards Points: 2,536
BT... Sorry, man but you were wrong and you missed the boat. The job is done and the op's house didn't blow up. Time to move on.
Bob Sanders is offline
Old 01-08-2017, 05:57 AM   #49
An old Tradesmen
He may, or may not have shut off the manual valve again. Hopefully he shut it off.
Old 01-08-2017, 07:52 AM   #50
Which would defeat the entire purpose of the pressure regulator.
BT.... Give it a rest. You're just embarrassing yourself now.
Old 01-08-2017, 08:11 AM   #51
An old Tradesmen
There are 2 schools on auto water feed valves.
1. Leave it open
2. Close it
Leave it open say to do so so that it can automatically maintain boiler water pressure.
Close it. Say to close it since if the system needs water, the system should be checked for a leak. plus, if the system springs a large leak, the auto water feed will just increase the amount of water damage.
For joetab24, no one knows if his auto feed bleeds through or not. Since none of us have ESP.
Old 01-08-2017, 08:43 AM   #52
It sounds like that autofeeder hasn't been used in a while so I would keep and eye on the pressure for a few days just to make sure it's working properly. It'll go up and down a little due to expansion/contraction of the water, but it shouldn't go up too high. If you notice water dribbling out the relief valve (usually happens when the pressure hits 30 pounds) then the feeder needs to be replaced.... otherwise... good luck!
Give it a rest BT
Old 01-08-2017, 08:52 AM   #53
An old Tradesmen
Yes, he can come home from work at lunch time and check it each day for the rest of the week. And just quickly swap it out if he comes home and finds the relief dripping water and not resetting.
Save
Old 01-08-2017, 09:14 AM   #54
Save
Oh dear lorde...
He can come home at lunch and find that a tornado ripped through his house too.
You go ahead and rattle on with your silliness BT. I won't laugh AT you... I promise!
Old 01-08-2017, 10:24 AM   #55
Rewards Points: 80
[quote=Bob Sanders;3864442]...quote]
I agree with BT.... It was a risk.
Cheers!
supers05 is offline
Old 01-08-2017, 11:21 AM   #56
[quote=supers05;3864802]
...quote]
Cheers!
Yes... I would figure you would see it that way after saying "SURE"! to dragging out a hose and filling through the DRAIN spigot.
Any.... "pro" would surely recommend such a move over the PROPER channel of filling a boiler!
As it turns out, the isolation valve was off which is why the boiler wasn't getting any water in the first place. I wonder why the.... "PROS" here didn't think of that first... particularly since the claim as of late (by BT) that it should be off because the are "2 schools of thought" on the auto feeder. BT's first thought is that the auto feeder is plugged... meaning he thought the isolation valve was.... ON. I wonder why the heck he would think it was on when there are "2 schools of thought"!?!!?
Want to know a REAL risk? Filling through the DRAIN spigot which is located at the bottom of the boiler where all the sediment is. Now that's a brilliant move! You blow all that sediment back into the water where now you REALLY stand a chance of a relief valve not seating properly. Great stuff guys!
You two sure you want to call yourselves.... "PROS"?
Old 01-08-2017, 11:33 AM   #57
Rewards Points: 80
[quote=Bob Sanders;3865042]
That spigot would hold a teaspoon of sediment... The 2 sediment taps hold to the right hold much more.
Cheers!
supers05 is offline
Old 01-08-2017, 11:49 AM   #58
[quote=supers05;3865066]
Cheers!
Not just the spigot. The whole bottom of the boiler. Water rushes through a hose at a much higher velocity than through an auto feeder. You would stir it all up pretty good. The higher velocity also increases your chances of overfilling and blowing the relief valve.
But hey... you guys just keep coming with these..... brilliant ideas! I mean really... why should anyone want to fill a boiler PROPERLY?
I have an idea... next time you need to go somewhere.... don't start the car.... just push it. If you start it, the accelerator pedal might get stuck!
Old 01-08-2017, 12:01 PM   #59
Rewards Points: 80
[quote=Bob Sanders;3865106]
Why on earth would you turn it on full bore......
Anyways, he was concerned for the OP. I thought about telling him to use the auto feeder, but BT already answered. I've also had them fail open after manually opening them, and it was a valid concern.
Monday would have been a better time to try. It wasn't a bad idea, just not great timing.
Cheers!
supers05 is offline
Old 01-08-2017, 12:22 PM   #60
[quote=supers05;3865146]
I wouldn't turn it on at all, because I wouldn't be caught dead doing something so dumb. However in your imfament wisdom in encouraging such a thing... you forgot to tell the op not to turn it on full bore
Closed Thread
