1 Flush Ok Or A Bit Weak, 2 Flush Very Weak, 3 Flush Always Ok - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-20-2016, 04:45 PM   #1
Rewards Points: 329
Question
1 flush ok or a bit weak, 2 flush very weak, 3 flush always ok
Here is something I've been trying to wrap my head around. I have a toilet that the first time I flush it it may not discharge fully. Like almost but not all the way. And the second time I flush it it barely moves. And yet the third time I flush it it goes right down. There's another toilet 1 floor up that does not seem to have that problem.
What's up with that?
Deck is offline   Reply With Quote
Old 09-20-2016, 06:57 PM   #2
Rewards Points: 3,436
Re: 1 flush ok or a bit weak, 2 flush very weak, 3 flush always ok
Could possibly be a venting, partial clog, or something stuck in the trap of toilet itself. Have to investigate a little further.
jmon is online now   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
Deck (09-21-2016)
Old 09-20-2016, 07:15 PM   #3
Rewards Points: 6,398
After finding a plastic butter tub lid in a problematic toilet of a house my son purchased I now believe anything is possible. Symptom: worked like new one time, not so maybe the next two times, then like new for two days. Threw the towel in so to speak and pulled it.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Deck (09-21-2016)
Old 09-21-2016, 05:03 PM   #4
Rewards Points: 1,932
First make sure the water in the tank is set to the correct level. Auger the toilet or plunge it hard.
Test
If still fails remove toilet and look up the bottom side for impacted feces. Remove feces.
It should work fine now.
The Following User Says Thank You to Ghostmaker For This Useful Post:
Deck (10-03-2016)
Old 09-22-2016, 01:56 PM   #5
Rewards Points: 2,636
OP's description a bit unclear to me:
Does the toilet tank not empty completely on each flush, requiring multiple flush lever/handle yanks to get a "complete flush"?
If it does empty completely then likely some sort of blockage as described by others. If not, then you have to monkey with the tank valve and related linkage IMO.
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
Deck (10-03-2016)
Old 09-23-2016, 01:20 AM   #6
Rewards Points: 329
Sometimes it empties completely and sometimes it doesn't. When it doesn't it's slower to empty.
Old 09-23-2016, 12:39 PM   #7
Rewards Points: 3,416
The flush performance may vary depending on how much water is in the bowl just before the flush and how much water came down into the bowl before the tank flapper dropped shut.
Stick to your lawn watering schedule until it really pours. Otherwise the storm might miss and the part that gets watered last (3 days away?) will dry up.
The Following User Says Thank You to AllanJ For This Useful Post:
Deck (10-03-2016)
Old 09-23-2016, 03:40 PM   #8
The toilet will not work properly if it is not filled to the right amount (a ballcock/float issue) and/or not dispensing correct amount of water on the flush cycle (flapper and related triggering mechanics).
Deck (10-03-2016)
Old 09-25-2016, 09:03 PM   #9
Rewards Points: 329
Ok well the water level was pretty low in that toilet so I tried adjusting it, I'll let you guys know what happens. It seems to be a very moody toilet. Thanks for all the advice so far.
Old 10-03-2016, 12:49 PM   #10
Rewards Points: 329
Thanks to everyone for their help. It's been about a week now without any problem. The water level is now about 2" - 2.5" higher than it was before I adjusted it. It was pretty low before. So I think the problem is solved.
The Following 3 Users Say Thank You to Deck For This Useful Post:
bob22 (10-03-2016), Ghostmaker (10-03-2016), jmon (10-03-2016)
Toilet Poor Flush Flapper Closing too Quick. doolenberg Plumbing 9 06-29-2015 09:07 AM
Flush Valve Seat sticking to Tank Ball Leah Frances Plumbing 2 05-23-2011 06:53 AM
Flush mount an outdoor load center? wmldwilly Electrical 1 04-29-2009 07:17 PM
