1/2" Supply - Any Reason For 3/4" Manifold? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-21-2016, 08:41 PM   #1
Rewards Points: 177
1/2" supply - any reason for 3/4" manifold?
I have a 1/2" water supply from the city. I'm redoing some plumbing fixtures in my home. Is there any reason to go with a 3/4" manifold?
RCGA is offline   Reply With Quote
Old 04-22-2016, 01:02 AM   #2
Rewards Points: 198
Re: 1/2" supply - any reason for 3/4" manifold?
You need all the help you can get. The 3/4" manifold will cause less friction loss. What is the pressure at the meter and how long is the run. These things work together to create a viable system however a larger main coming from the meter would work much better to give you volume and more pressure when you turn on your faucets.
srloren is offline   Reply With Quote
Old 04-22-2016, 06:41 AM   #3
Rewards Points: 18,776
Anyone else ever seen just a 1/2" main line supply?
That just sounds wrong to me.
There would not be enough volume at any pressure.
Old 04-22-2016, 08:45 AM   #4
Rewards Points: 3,216
Usually main is 3/4 or 1 inch coming into house. Have seen them reduced to 1/2 inch right after water meter. Check and see. Post a pic when you can.
If thats the case, as mentioned above, you'll need all the help you can get.
jmon is offline   Reply With Quote
Old 04-22-2016, 09:16 AM   #5
Rewards Points: 177
Water supply is on the far right
Old 04-22-2016, 11:44 AM   #6
Can't really tell from the pic, as its just out of frame, need close up of where main actually comes in. Looks like it was reduced to 1/2in somewhere.
Supply valve to bath faucet doesn't stop water Kurt123 Plumbing 2 09-05-2010 09:48 PM
New Faucets - Rural Water Well Supply terra3 Plumbing 2 02-25-2010 05:41 PM
Extending Water Supply Box In Laundry Room hsl Building & Construction 0 11-18-2009 09:21 AM
help w/ duct sizes & new supply locations palex1915 HVAC 0 10-13-2009 07:52 PM
increasing washer supply lines to 3/4" instead of 1/2" amatchin Plumbing 3 04-15-2006 04:23 PM
