1 1/4" To 1 1/2" - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By RRH
Old 12-27-2016, 05:08 PM   #1
Rewards Points: 104
1 1/4" to 1 1/2"
I am installing a sink in a bathroom for a relative, and discovered that the drain in the wall has a 1 1/2 inch male. The sink drain is 1 1/4" as I expected.
I found a reducer washer that works and doesn't leak (yet) - but it doesn't feel as solid as I would like. I was looking for an adapter that would screw in to 1 1/2 male and provide and 1 1/4" male to connect the arm to.
Thanks!
tribe_fan is offline   Reply With Quote
Old 12-27-2016, 05:44 PM   #2
Rewards Points: 18,976
Re: 1 1/4" to 1 1/2"
Sounds like you did it right.
Most trap adapters come with that 1-1/2 X 1-1/4 washer.
Picture would be nice so we can see what your seeing.
tribe_fan (12-27-2016)
Old 12-27-2016, 05:52 PM   #3
RRH
Rewards Points: 1,480
I would consider the 1 1/2" a plus.
Use all 1 1/2" J-pipe and P- trap and use the washer between p trap and sink tail piece.
Yodaman likes this.
RRH is offline   Reply With Quote
The Following User Says Thank You to RRH For This Useful Post:
1/2" or 1/4" Durock Cement Board? HanDIY Flooring 5 05-11-2018 06:08 PM
1/2" vs 1/4" drip line vs 1/2 Poly with Emitters Splais Landscaping & Lawn Care 5 07-22-2015 10:35 AM
1/2" NPT brass nipple with 3 1/4" length needed. noone Plumbing 10 08-09-2013 05:49 AM
1/2" vs 1/4" drywall jackwashere Drywall & Plaster 7 06-01-2012 04:19 PM
1/4" or 1/2" cement board? kemerick Flooring 4 09-14-2007 11:42 AM
